dented door
Old Jan 21, 2008 | 03:31 PM
twiztid00002's Avatar
Default dented door
ok so i had to change my oil and i had a discount thing a jiffylube and the price would equal out to be the same if i did it so i was lazy and let jiffylube do it. after they pulled it out of the garage i saw a dent like 8 inches wide and 2 inches tall right under the door handle. they didnt admit to anything! no wonder.
and ideas about getting it fixed. should i pay for it or like take off the door panel and use a rubber mallet to hit it out or somethin?
Old Jan 21, 2008 | 03:57 PM
Giant_Bean's Avatar
Default Re: dented door (twiztid00002)
look for a paintless dent repair place, they should be able to pop it out
Old Jan 21, 2008 | 03:58 PM
also.. i dont know wat they did but my car feels to be slower
Old Jan 21, 2008 | 05:17 PM
ethereal2pt2's Avatar
you should be more concerned about how deep the dent is. last year my neighbor backed into my driver side door and when i got it estimated they said 700. apparently the door was dented deep enough where the metal was stretched and if that's also the case for you, from what i recollect, they have to heat treat the metal first and pop it out to get it to sit properly. otherwise, when you pop the dent out, the stretched metal will stick outwards rather than inwards and you'll have an inverse dent. i would go try using some old tricks like rubbing dry ice or the hair dryer and air duster trick. but ppl usually use these methods for smaller dents. never hurts to try though. good luck. i feel your pain.. i still haven't fixed mine yet.
Old Jan 21, 2008 | 05:28 PM
Default Re: dented door (ethereal2pt2)
its not too deep but how do u do those tricks u said?
GPC91
Dec 7, 2012 06:00 PM
DTMkarnage
Jun 15, 2010 01:02 AM
suhteevin
Jan 6, 2009 09:04 PM
chiggin
Honda Civic (2006 - 2015)
Aug 28, 2007 11:31 AM
Keane Rated R
Aug 22, 2001 03:51 PM
