Crower Cams
yes, the stage 3 is the drag profile, idle will undoubtly be erratic. although the lift isnt much bigger than a type-s cam (intake, anyway).
He's right, just tune it and it should idle decently. Even if it didn't, for $50 more Crower will make you a cam with Stock idle lobes and Stage 4 VTEC lobes.
Talk to vntperformance about the Crower Stage 3s. He used to run them in his Prelude. IIRC, he later switched them to the Stage 2s - I'm not sure why, but he probably had a good reason.
C5_ALLMOTOR: I haven't heard of any broken Crower H22A cams yet. I assume you are refering to the B series cam failures...
Andrew
Andrew
with the stage 2 you dont need the valvetrain kit if you don't exceed stock rev limit right?? also there are two stage 2's on the crower site, anyone know the diff?
thanks yall
D
thanks yall
D
AlexLude
Mar 29, 2004 01:35 PM
