Correcting ATTS problem.
I have had my ATTS light on for a while now and I Check the code and it turned out to be code 62 which is the left oil pressure sensor. Would replacing the sensor fix the problem or could the whole system be shot? I no there is not much information on the ATTS and its a real pain in the *** but I just want fix it rather than looking into a new transmission or a base swap or is it not worth it?
Any input would be appreciated.
have you ever worked on an ATTS system. Do I have to drop the motor to get to the sensor or is there any way to replace it without taking the whole atts system out?
Replacing the sensor will most likely fix the problem and it can be done without dropping the system. I had to do this once before. However, it is very much a pain in the ***.
Also, a new sensor is about $250 from Honda (or $175 online). So try to find a used one like I did.
