compression and horsepower
Old Nov 30, 2005 | 11:06 PM
fastfu's Avatar
Default compression and horsepower
im going to be fitting an accord type R cylinder head to my lude the thing is that the accord type R comes with 11:1 compression and my lude has 10:1.
how much does 1 point of compression equal in horsepower
Old Dec 1, 2005 | 12:40 AM
onefastrx7turbo's Avatar
Default Re: compression and horsepower (fastfu)
There's no real set formula, considering every motor is different. Plus, mods and fuel octane and such will affect it.
Old Dec 1, 2005 | 12:45 AM
fastfu's Avatar
Default Re: compression and horsepower (onefastrx7turbo)
so on a stock motor how much hp difference would 1 compression point make
Old Dec 1, 2005 | 03:24 AM
Grand's Avatar
man he just told you you cant exactly tell have the head milled or a thinner headgasket and flat face valves and get that 11.1-1 or more out of it and dont lose any power
Old Dec 1, 2005 | 04:03 AM
kulrevon's Avatar
Default Re: (LG_R32)
just checking with fastfu. but I dont believe the cyclinder head from the accord will change compression? isnt it the pistons?
Dont get me wrong I know you can change compression with milling and flat valves and such. but are the dishes in the accord head different then the prelude?
Old Dec 1, 2005 | 04:17 AM
fastfu's Avatar
Default Re: (kulrevon)
i know that the head won't change the compression i was asking what the hp difference was betwwen 10:1 and 11:1
the accord type R has 212hp and my uk 2.2 prelude has 185hp
i was trying to work out how much hp i will gain without fitting 11:1 pistons
Old Dec 1, 2005 | 04:20 AM
mgags7's Avatar
you will probably make up more than half of that 17hp with the cams.....but the pistons would be a good choice....you could always get flat face valves and a thin hg to get 11:1.....
Old Dec 1, 2005 | 04:38 AM
fastfu's Avatar
Default Re: (mgags7)
no-one makes flat face valves for the accord type R as they have 60 degree valve seats whereas the prelude H22 has 45 degree seats
Old Dec 1, 2005 | 05:35 AM
PirateMcFred's Avatar
Default Re: (fastfu)
Just about any engine machine shop should be able to regrind valves to accomodate any seat angle. Or talk to valve companies available in the UK about valves that come with a 60º angle. Milling the head .025" and getting cam gears to adjust for the retardation will increse your compression a bit too.
Pirate
Old Dec 1, 2005 | 10:13 AM
precord96's Avatar
1 point in compression is usually about an increase in 4% of power
Old Dec 1, 2005 | 02:45 PM
hondavtecguy's Avatar
Default Re: (precord96)
does the higher compression also help with torque asmuch as hp? Or does it just maily help with hp?
Old Dec 1, 2005 | 04:25 PM
thegrenone's Avatar
for a quick answer a H22A4 or the prelude type s has 11.1-1 compression and it only has 220 and little higher torque
Old Dec 1, 2005 | 04:36 PM
The Birdman's Avatar
Default Re: (thegrenone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegrenone &raquo;</TD></TR><TR><TD CLASS="quote">for a quick answer a H22A4 or the prelude type s has 11.1-1 compression and it only has 220 and little higher torque</TD></TR></TABLE>
h22a4 is not the type s
Old Dec 1, 2005 | 09:49 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (hondavtecguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondavtecguy &raquo;</TD></TR><TR><TD CLASS="quote">does the higher compression also help with torque asmuch as hp? Or does it just maily help with hp?</TD></TR></TABLE>
wow
dude horsepower is a function of torque, you cannot get one without the other. Look at a dyno graph, look at 5252 RPM what do you see.
Horsepower = torque * revs/minute * minute/60 s * 2*pi * 1/550
Horsepower = torque * revs/minute * 1/5252
Horsepower just means how much torque your engine is making at a given RPM.
Techna600f4i
Jun 19, 2006 11:49 PM
zoom545
Nov 22, 2005 09:04 AM
madjdmy0
Oct 15, 2005 11:37 AM
jeremy.
Sep 25, 2003 01:44 PM
mikeyvt
Nov 30, 2002 10:14 AM
