Clutch replacment
Old Mar 15, 2007 | 02:01 AM
jdmh22a1's Avatar
Default Clutch replacment
for the guys change ur clutch..urselves...whats the average time...bc my friend is gonna help me he is a mechanic at a local honda repair shop and said it will probably take all day..?? i just wanna know...if thats too long..or what??? thnx
Old Mar 15, 2007 | 02:45 AM
user 720822-1's Avatar
Default Re: Clutch replacment (jdmh22a1)
I'm gonna do it myself, but in my case the engine is out (gonna be swapped to H22), so then it will take "minutes" instead of hours.
With the right tools you could do it in a litlle more then half a day I guess.
Just curious: is their an how-to for changing your clutch and flywheel (only thing I saw was a how-to how to get the transmission of, but not how to fit and install the flywheel and clutch??)
Old Mar 15, 2007 | 05:20 AM
jdmlude5
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22a1 &raquo;</TD></TR><TR><TD CLASS="quote">for the guys change ur clutch..urselves...whats the average time...bc my friend is gonna help me he is a mechanic at a local honda repair shop and said it will probably take all day..?? i just wanna know...if thats too long..or what??? thnx</TD></TR></TABLE>
i can do mine in like 3 hours. but i have done it alot also. so a half a day sounds about rite
Old Mar 15, 2007 | 12:42 PM
Default Re: Clutch replacment (Black-Engine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">
Just curious: is their an how-to for changing your clutch and flywheel (only thing I saw was a how-to how to get the transmission of, but not how to fit and install the flywheel and clutch??)</TD></TR></TABLE>
Anyone?
Old Mar 15, 2007 | 12:48 PM
93sivtec's Avatar
No that sounds good.Mine took me the majority of the weekend,but I was taking my time,waiting for the machine shop,and it was my first time ever doing it.Carefull with the ball joints,if they are old,they are easy to tear.Also make sure u lube the living **** out of the throw out bearing....or it will make an annoying buzz.
Old Mar 15, 2007 | 02:55 PM
glazethatj's Avatar
Default Re: Clutch replacment (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna do it myself, but in my case the engine is out (gonna be swapped to H22), so then it will take "minutes" instead of hours.
once you have the trans out you just unbolt the pressure plate from the flywheel then take off the clutch and unbolt the flywheel. do the reverse to put it on but make sure you use an alignment tool. and tighten each bolt on the flywheel and pressure plate a little at a time so it sits right
Old Mar 17, 2007 | 07:34 PM
jdmh22a1's Avatar
god damn...that ****...was hard on the floor...expletive....it was so so to take off the trans but when ur on the ground its hard...to put it on...!!!..but got it on...
Old Mar 18, 2007 | 12:10 AM
MLBZ521's Avatar
Wow guys... This place is to help each other out and common problems have been asked/answered before... Search, it's your friend.. Not to mention we have a FAQ... LOTS of GREAT INFO in there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Engine &raquo;</TD></TR><TR><TD CLASS="quote">Just curious: is their an how-to for changing your clutch and flywheel (only thing I saw was a how-to how to get the transmission of, but not how to fit and install the flywheel and clutch??)</TD></TR></TABLE>
Get a Helms Manual and then read this:
https://honda-tech.com/zerothread?id=907431
And then do it with the combined knowledge of the Helms Manual and that How-To.
prelude_93vtec
Oct 16, 2007 12:19 PM
Lauj87
Sep 9, 2005 05:26 AM
Apocolipse269
Sep 7, 2005 01:14 PM
92hondalude
Dec 21, 2004 12:44 AM
redteg1
May 12, 2003 11:23 AM
