clutch problem possibly?
ok so i go into first and shift into second
i try to go over 2rpms and when i do it revs..while im moving
every gear seemingly revs if i give it more gas than a little tap
i wouldnt know what the problem is....
anyone?
anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOP END MS »</TD></TR><TR><TD CLASS="quote">If your running an Exedy stage 2 I know what the problem is.</TD></TR></TABLE>
Well if you know the problem then why didn't you type it? Are you trying to gain posts or something? If you're going to help then help, otherwise, don't post...
To the OP, I'm not sure that your problem is in the clutch, unless its not engaging completely and you are just burning it, but I think it might be a problem elsewhere, when you are stopped, does it rev on its own?
Max
Max
nope it just cant rev past like 2rpms without burning it somewhat and even then it still doesnt catch
idk pressure plate fucked is what i think
welp new clutch time......i guess
