clutch problem
Old Oct 20, 2006 | 07:53 PM
msinsky14's Avatar
Default clutch problem
I had my clutch replaced under 2K miles ago, but I was driving and I couldnt seem to get it into any gear, car was warm. the clutch was also stuck at about 1/3 the way off the floor, but I can pull it up and it wil stay. it also has no pressure until that point. any ideas whats wrong? I searched and my problems seem different than others
Old Oct 22, 2006 | 05:19 PM
msinsky14's Avatar
Default Re: clutch problem (msinsky14)
bump, any help at all
Old Oct 22, 2006 | 05:33 PM
NICEHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">I had my clutch replaced under 2K miles ago, but I was driving and I couldn't seem to get it into any gear, car was warm. the clutch was also stuck at about 1/3 the way off the floor, but I can pull it up and it will stay. it also has no pressure until that point. any ideas whats wrong? I searched and my problems seem different than others</TD></TR></TABLE>
Check your clutch fluid in your reservoir. I think it may be low on fluid or you may have a leak in your line somewhere. When I had experienced that problem I had an issue with my clutch slave which was leaking. After I had it replaced it was fine.
Check it out.
Old Oct 22, 2006 | 10:26 PM
Marz's Avatar
Default Re: clutch problem (NICEHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NICEHATCH &raquo;</TD></TR><TR><TD CLASS="quote">
Check it out. </TD></TR></TABLE>
YUP................pretty sure may be a leak........
Old Oct 24, 2006 | 05:18 PM
msinsky14's Avatar
Default Re: clutch problem (Marz)
I just had a friend press the brake in and my master cylinder squirted fluid like a super soaker . so looks like I gotta replace it this week, thanks
legend97
Transmission & Drivetrain
Jul 6, 2017 07:45 AM
B18EG6
Feb 20, 2005 07:16 PM
onyx00
Dec 11, 2004 02:56 PM
monsterb18b
Nov 20, 2003 09:45 AM
92 civic VX B18c
Sep 30, 2003 03:34 AM
