cel 12 help
Old Dec 1, 2004 | 11:48 AM
shooitzlinh's Avatar
Default CEL Code 12 help
i drive a jdm h22 hatch and as i was coming home i punch the gas. once i hit 5k the car started to pop. So i went home and checked my cel and it blinked once for a while then one quick on so that is cel 12 EGR - exhaust gas recirculation lift valve. does this have to do with vtec at all? and what do i do to fix this
Modified by shooitzlinh at 9:18 PM 12/1/2004
Modified by shooitzlinh at 9:22 PM 12/1/2004
Old Dec 1, 2004 | 12:22 PM
Default Re: CEL Code 12 help (shooitzlinh)
bump i need to get it fixed
Old Dec 1, 2004 | 12:29 PM
chitownrida's Avatar
make sure the vac line going to the top of the egr has good vaccum pressure .. i had mine hooked up wrong. when i threw a code 12
Old Dec 1, 2004 | 12:31 PM
98TypeSH's Avatar
Default Re: (chitownrida)
Also make sure your EGR is clean and not sticking. When in doubt, pull it off, spray it with some carb cleaner then reinstall. If that doesnt fix your problem you EGR is dead or vac is incorrect.
Old Dec 1, 2004 | 01:15 PM
Default Re: (98TypeSH)
i tried cleaning the egr valve and were are the egr ports on a jdm h22. If the ports clog up what will happen?
Modified by shooitzlinh at 11:14 PM 12/1/2004
Modified by shooitzlinh at 12:10 AM 12/2/2004
Old Dec 1, 2004 | 04:53 PM
Default Re: (shooitzlinh)
help
Old Dec 1, 2004 | 05:50 PM
ludegetsmwet's Avatar
your egr connects right on top left of the intake manifold. there should be a valve and sensor to check valve opening or lift. like 98typesh said take it off spray with carb cleaner and check for good vacuum and should be no problem. also how many miles are on the motor. The exhaust gas recirculation valve will get clogged after so many miles and will require you to clean it.
Old Dec 1, 2004 | 05:54 PM
Default Re: (ludegetsmwet)
umm its a jdm motor and i just had it in for 2 months so yeah its around 30 to 40k and i did clean out the egr valve but that didn't do anything. could a bad jdm h22 distributor be the problem because the need is jumping um and down but its not reving at all. if i change out the distributor what could i use since i cant get a hold of a jdm h22 distributor.
Old Dec 2, 2004 | 10:00 AM
bump
Old Dec 2, 2004 | 10:07 AM
Sam1am26's Avatar
Well just because the egr wasn't clogged doesn't mean that the port in the intake manifold where it meats the cylinder head isn't clogged... I have heard of people having to remove the intake manifold to unclog the port just to get rid of an egr cel... but that would have to be some serious clogging...
Old Dec 2, 2004 | 10:15 AM
98TypeSH's Avatar
Default Re: (Sam1am26)
It really shouldn't be that much work to remove an intake manifold on a h22 swapped civic. Its a different story on a lude with EVERYTHING in the engine bay. Check the little vac diaphragm for the EGR sensor. If that thing is sticking or not working thats the problem. You claimed you have taken the EGR off to clean it, then you should know where the vac line is and where it plugs into.
Old Dec 2, 2004 | 01:22 PM
Turbogixxer's Avatar
Quick question, is it even wired up correctly?
What you using for your valve solenoid (for EGR)?
Old Dec 2, 2004 | 04:29 PM
Default Re: (turbogixxer)
yes it was wired up correctly i've been driving it for two months with no problems til now. i am going to try cleaning out the intake manifold this weekend.
esanchez
Aug 22, 2010 05:26 PM
NICEHATCH
Aug 31, 2006 11:47 AM
