car sputtering??.....
Old Apr 10, 2003 | 12:24 PM
One Slow Lude's Avatar
Default car sputtering??.....
So.... When I first start my car (even when it warms up) and first start driving there is a big hesitation in first. like i can put the pedal to the floor and it wont rev higher, then after like 2-3 seconds it'll jump forward. Also, recently (past 3 days) when i am cruising through town at like 45mph and on the gas slightly just to keep speed, the car feels like it is sputtering, but if i get on it it goes away. Also, sometimes if i blip the throttle when it hasnt been run yet the revs wont go up, like the throttle response is REAL shitty. Do you think my fuel pump is going or my injectors are clogged. Should i disconect the battery and see if the computer kinda "resets itself"? please help. TIA
Old Apr 10, 2003 | 12:34 PM
4bidden's Avatar
Default Re: car sputtering??..... (POSlude97)
Welcome to the great world of the Prelude hesitation. Be sure to let me know if you find out what is causing it. I've had it for over 10 months.
Old Apr 10, 2003 | 01:12 PM
Fly1865's Avatar
Default Re: car sputtering??..... (4bidden)
I'd say try the little things first, i just started having this problem after i rebuild my H22. Didn't have the problem up until i rebuild it and put about 1300 miles on it. only think i can think do is run some injectors cleaner and buy some intake clearer and go to town.
But if you figure it out please let all of know.
Old Apr 10, 2003 | 02:11 PM
Log4n's Avatar
Default Re: car sputtering??..... (Fly1865)
ok I just had to deal with this exact problem, heres what I did:
1.new sparkplugs (checked wires---looked fine)
2.new distributer cap (checked rotor---looked fine)
drove car around for a little while, helped a little but the problem was still there (mainly the hesitation)
3.new fuel filter (very dirty)
4.used some stp throttle body cleaner
drove car around some more, helped even more but still had a little hesitation
5.dropped a bunch of chevron fuel injection cleaner in the gas tank
after a couple tanks of gas were gone through the problem has gone away
one last thing-check your compression, if your compression is really low because of the rings being worn out you, will experience the hesitation and so forth especially at low rpm's.
Old Apr 10, 2003 | 02:12 PM
4bidden's Avatar
Default Re: car sputtering??..... (Log4n)
Hymmm, so you are saying it was your injectors or something in the fuel supply system since the cleaner made it go away?
Old Apr 10, 2003 | 04:32 PM
i was figurin it had something to do with the injectors, cause thats what it seems like. I just had my engine replaced brand new from Honda 8 k miles ago, so i doubt its the rings....but ill check. i am bettin that the dealership didnt change any of the fuel system components thats why i was figuring thats what it was.... I try your opinion and see how it goes.
4bidden....how is it going with the short shifters?
Old Apr 10, 2003 | 07:14 PM
4bidden's Avatar
You asked so I guess I don't mind going OT in your post....
I finally got a 5gen stock shifter and...well...uhm....it's not made to come apart. I am going to have to sell the complete shifter/base plate portion as a unit. It will be direct bolt in, just replace the whole stock piece. The huge white plastic part on the stock shifter does not come off.
Old Apr 11, 2003 | 10:19 AM
MugenPoweredLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POSlude97 &raquo;</TD></TR><TR><TD CLASS="quote">So.... When I first start my car (even when it warms up) and first start driving there is a big hesitation in first. like i can put the pedal to the floor and it wont rev higher, then after like 2-3 seconds it'll jump forward. Also, recently (past 3 days) when i am cruising through town at like 45mph and on the gas slightly just to keep speed, the car feels like it is sputtering, but if i get on it it goes away. Also, sometimes if i blip the throttle when it hasnt been run yet the revs wont go up, like the throttle response is REAL shitty. Do you think my fuel pump is going or my injectors are clogged. Should i disconect the battery and see if the computer kinda "resets itself"? please help. TIA </TD></TR></TABLE>
Hey, I have the same exact problem....i doubt its my compression i only have 33K on the motor and i dont abuse it
just ordered some plugs and wires see if that works but i also got a code 71 which is misfire cylinder 1 so that can be directly related to my ignition...ill try the fule cleaner too
Old Apr 11, 2003 | 11:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">I am going to have to sell the complete shifter/base plate portion as a unit. It will be direct bolt in, just replace the whole stock piece. The huge white plastic part on the stock shifter does not come off. </TD></TR></TABLE>
I guess that might explain why companies are only putting out adaptors for them instead of true short shifters..... Good luck if you still are going through with it
Ok this is OT too, but I can't get my shift **** off.....like Im not that dumb (i dont think) But when i turn the shift **** the whole boot turns too, i looked for a locking nut or something to squeeze but to no avail
MugenPoweredLude: What wires did you get. I should probably try to change mine too.
Has anyone had a problem with this hessitation on the drag strip?
Old Apr 11, 2003 | 11:26 AM
4bidden's Avatar
The hesitation made me go from 14.3@98 to 14.6@94. So yea, it DOES hamper your low and top end, even though it feels like it goes away top end.
Stick a flathead between the boot and the chrome ring and pry downwards while pullling down on the boot.
Old Apr 11, 2003 | 11:27 PM
2k1_ITR_0736's Avatar
pos: u should have bought an R
heh heh
Old Apr 12, 2003 | 11:40 AM
punksteroo's Avatar
if i pull the injectors, is there any easy way to clean them out??...that fuel additive injector cleaner never works..it's just like running a little bit of HIgh Octane fuel...
Old Apr 12, 2003 | 12:04 PM
LudeyKrus's Avatar
Default Re: (punksteroo)
My car has done the same for a LONG time. I get a motor w/ 100k dropped in, and it did it when i first got it in. It kept sputtering for a long time, then eventually kinda went away. Recently, it's done it the past few days. I used to notice that it would do it when the car had sat in cold weather over night, or if it was rainy.
Old Apr 12, 2003 | 01:09 PM
props_honda85's Avatar
Default Re: (LudeyKrus)
Hey, wat'd yall know my 96 Si has a 130k on it and its done that off and on during the winter when it gets cold, but i live in Central Texas so i only have to worry about my motor being cold for about 2 months outa tha year..in hot weather it doenst seem to do it or if it does, not as bad...but yea i feel ur pain!
Old Apr 12, 2003 | 03:14 PM
I ordered Magnecor 8.5mm wires and i got Denso Iridium plugs on the way next week....ill post up when i install them...hope it helps....if not im gonna change out the distributor/rotor
Old Apr 13, 2003 | 02:10 PM
Default Re: car sputtering??..... (MugenPoweredLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude &raquo;</TD></TR><TR><TD CLASS="quote">I ordered Magnecor 8.5mm wires and i got Denso Iridium plugs on the way next week....ill post up when i install them...hope it helps....if not im gonna change out the distributor/rotor </TD></TR></TABLE>
Cool, keep us posted!!!
Old Apr 13, 2003 | 02:56 PM
yup will do
Old Apr 13, 2003 | 09:19 PM
4bidden's Avatar
Default Re: (MugenPoweredLude)
A buddy of mine, ALTERED4 here on the board, had some NGK wires laying around that I put on and the car feels pretty good. No noticable hesitation yet. But its known to come/go as it pleases. Only real way to tell is to take it to the track.
Old Apr 13, 2003 | 09:34 PM
Default Re: (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">But its known to come/go as it pleases. </TD></TR></TABLE>
dude that is the worst part about it.....everytime i have someone in the car and i ask them about it or let them drive it it doesnt happen.....i feel like such an ***..
Old Apr 13, 2003 | 09:36 PM
4bidden's Avatar
Default Re: (POSlude97)
Yep, I took my buddy for a ride and he was like "Man, I don't feel any hesitation". It felt alright to me also. And I went out last night and did some aggressive driving and the car felt really good. Accelerated smoothly and the idle seemed better. Maybe I'll take it to the track this week and see if she's her old self again.
Old Apr 13, 2003 | 09:41 PM
ngk wires huh? ill have to def make that one of my next investments.
Old Apr 13, 2003 | 10:01 PM
4bidden's Avatar
Just get some stock wires if you have a hookup at Honda...same thing, except black.
Old Apr 13, 2003 | 10:04 PM
are there better wires to get, or does the prelude not like aftermarket wires? i know some cars act funny like that sometimes.
CivicSweetie01
Honda Civic (2001 - 2005)
Sep 24, 2011 07:16 PM
StolenTeg
Apr 21, 2005 08:02 AM
Ravage70
Jun 25, 2004 08:14 AM
Type RS
Jan 26, 2004 05:09 PM
