Camber Kit?
Im planning on lowering my 99 Base prelude about 1.3 - 1.5 inches at most. I did some searing and found that there is a lot of debate about needed a camber kit at this drop or not. Could some of you that have dropped your prelude this much let me know if you got a kit or not? And if so what kind of kit you would reccomend?
I was thinking of either going with a Ground Control Coil Over Setup or a set of springs, perhaps from Eibach or Tein.
Thanks,
-Jeff
Thanks,
-Jeff
you wont need a camber kit if you're only looking to 'drop' your car 1.5 inches. i have my car 1.5 inches lower all around and no problems yet. it doesnt look to me like there is any camber needed to be adjusted. BTW, i have progress group sport springs
It just depends really because I lowered mine 1.5 and my camber was -2.5 all the way around. After you lower it get your alignment done and find out what your camber is and that will let you know if you need to get one.
