CAI question
Old Aug 17, 2004 | 11:04 AM
delguiner's Avatar
Default CAI question
Ok guys this MAY be pretty complicated to explain... I have a 1992 prelude SI and i have a rust spot starting in the engine bay... now explaining where it is will be a problem... its actually right under the OEM filter box... its right next to that black plastic hole where the OEM air box actually gets some air from outside..
here's my question: Is that where you would have to put your hole for a CAI? or am i totally off? im kinda new to CAI's so any help would be nice :D
Old Aug 17, 2004 | 11:05 AM
98TypeSH's Avatar
Default Re: CAI question (delguiner)
yea, thats the spot that you have to cut for the pipe to go .
Old Aug 17, 2004 | 11:06 AM
Sephro's Avatar
Yeah that's where you would put the CAI. Some you don't need to cut a larger hole some you do.
Old Aug 17, 2004 | 11:07 AM
delguiner's Avatar
Default Re: CAI question (Sephro)
cause repairing the rust spot would probably be a lot more expensive....
Old Aug 17, 2004 | 11:11 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner &raquo;</TD></TR><TR><TD CLASS="quote">cause repairing the rust spot would probably be a lot more expensive....</TD></TR></TABLE>
Just cut out your hole and sand down the rust and seal it.
Old Aug 17, 2004 | 11:12 AM
delguiner's Avatar
cause iwould have to cut out the rust and stuff... and it would be great if i didnt have to weld anything cause thats where it would become expensivE!
98TypeSH's Avatar
no it wouldent. grind it/sand it, then paint it with some rustoleum primer or paint and there you have it. Or just get a cai and cut the bastage
Old Aug 17, 2004 | 02:40 PM
LudaMan's Avatar
Look what I can do!
Default Re: CAI question (98TypeSH)
all i did was kinda bend the edge of the hole down a little bit and my CAI fit perfectly, then i put a rubber seal around the hole and it worked
mario-SI-08
Honda Civic (2006 - 2015)
38
Mar 20, 2008 04:27 PM
PhilMac
Jan 22, 2008 07:51 AM
mrnewguy
Oct 10, 2006 08:12 PM
vxnine
Oct 18, 2004 12:05 PM
