a/c control panel and defrost
Old Jul 6, 2005 | 07:24 PM
seanj's Avatar
Default a/c control panel and defrost
a couple of years ago the a/c quit in my 89 prelude. shortly thereafter the panel with the a/c buton and all the other vent controls quit working. actually when you push the a/c button the aux. fan comes on so that switch is probably o.k. however you cannot select anything as far as where the air blows,when it broke it was on the dash vents and that's where it has been ever since. so that means no defrost in the winter. which brings me to the defrost issue. even when it did work it was horrible as in just roll the damn windows down. and yes that sucks in the winter,and yes that sucks when it rains and the windows fog up. this is the second honda i've had with nearly non-functional defrost,even when the a/c worked and you used it in defrost mode it was still pretty bad.is there a better blower motor i can get or is this just the price of driving one of the best cars made?
Old Jul 6, 2005 | 08:18 PM
pr1mo_13's Avatar
this brings me to an issue i have also. my 92 prelude won't switch off anything but defrost. what coudl be the issue here? the lights on the control panel buttons don't come on so could there be a connection problem? i'm going to dig in tomorrow so help soon woudl be great. thanks. sorry to hijack
Old Jul 6, 2005 | 08:26 PM
plikit's Avatar
Default Re: (pr1mo_13)
dunno about the 89 defrost but the 92-96 models had a problem where some of the solder points broke on the circuit board causing it to stop responding.
Old Jul 6, 2005 | 08:43 PM
pr1mo_13's Avatar
so where is this circuit board? behind the control panel?
Old Jul 6, 2005 | 09:44 PM
yOnKiNaToR's Avatar
The cuircuit board is inside the climate control. You have to take it apart to get at the board.
On the circuit board there is the green plug. On the other side of the green plug there are a bunch of soldered connection points. Those are the ones that need to be resoldered. Check them closely for cracks and you'll see what I mean. Just Resolder them and check again to make sure there are no hairline cracks in the solder and it should work.
This is for 4th gens btw.
Old Jul 7, 2005 | 12:06 AM
plikit's Avatar
Default Re: (yOnKiNaToR)
yup just resoldered all mine a couple weeks ago. works great now. and it only cost me a couple hours of my time. cant beat that.
Old Jul 7, 2005 | 08:39 AM
pr1mo_13's Avatar
i must be retarded since i can't get mine out of the dash.. the vents won't pull out and after pulling 2 screws from the bottom of the a/c panel it won't come out..
Old Jul 7, 2005 | 12:29 PM
seanj's Avatar
so...... does anybody know anything about the 89's?????
Old Jul 14, 2005 | 05:16 PM
plikit's Avatar
theres a 3rd screw in the back holding in the vents/control unit. you have to drop the section of the console that holds the stereo to get to it.
Old Jul 14, 2005 | 07:44 PM
92SleeperH23's Avatar
Default Re: (plikit)
just a heads up, getting the climate control unit itself apart is a bitch.
There's a bunch of little clips going around the edge, then once you've gotten the faceplate off, all the buttons are barely connected with a little hook on a spring, and they move around a lot, so when you're putting it back together it's hard to line up all the buttons with their holes
good luck
I took mine apart a couple weeks ago, but my dad (electrician/computer guy) said all the solder points were good
Old Jul 24, 2005 | 07:18 AM
plikit's Avatar
Default Re: (92SleeperH23)
id reccomend resoldering them anyways. then youll know for sure if that was the problem.
Bangher4$
Honda Civic (2001 - 2005)
11
May 22, 2009 01:25 PM
ScoobCivic
Aug 2, 2004 02:11 PM
pr0digy1
Oct 17, 2001 01:43 PM
