Brake trouble...
Old Apr 28, 2004 | 10:28 PM
Usfrob22's Avatar
Default Brake trouble...
Well installed SS lines and AEM big rotor kit w/AEM pads earlier today....Goto start the car up and break in the pads/rotors and wtf....the pedal is hitting the floor.
So we jack the car up and bleed the brake one more time just to make sure but the **** is still hitting the floor. Also when the pedal is depressed there is a hissing/sucking sound comin from under the hood in the vacinity of the abs unit/master cyl/booster.....
Someone mentioned i might have blown out one of the seals on the master cylinder, just wondering if anyone else had any ideas...
Old Apr 28, 2004 | 10:33 PM
Tomservo's Avatar
Default Re: Brake trouble... (Usfrob22)
Definitely sounds like a master cylinder problem...the only other thing brake-related where that hissing noise is coming from is the brake line itself...which I guess could be the culprit if it is ruptured and is sucking in air...are you leaking brake fluid?
Old Apr 28, 2004 | 10:36 PM
Usfrob22's Avatar
Default Re: Brake trouble... (Tomservo)
nope absoloutlly no leaks anywhere, while bleeding the system the 2nd time the fluid level did dip a bit below the min line on the resevoir....could that have damaged the master cyl?
Old Apr 28, 2004 | 10:39 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usfrob22 &raquo;</TD></TR><TR><TD CLASS="quote">nope absoloutlly no leaks anywhere, while bleeding the system the 2nd time the fluid level did dip a bit below the min line on the resevoir....could that have damaged the master cyl?</TD></TR></TABLE>
No, that would just cause the MC to suck in some air, which could have happened...In which case you just need to bleed the **** out of it....Trust me, I converted my car from ABS to non-ABS and did all of this stuff over and over....
i say bleed it 20-30 pumps at each wheel and then if not fixed, MC is probably ...
Old Apr 28, 2004 | 10:41 PM
Tomservo's Avatar
I don't think so...I think that would just suck air into the system at worst...which would mean you would have to bleed the whole thing over again...But I don't think it would hurt the master cylinder...however...Here's an idea...If your master cylinder's seals were old, they may have been starting to fail anyways just due to age...then you add new brake parts and stainless steel lines, and that will put more pressure on the seals...THEN you add more brake fluid which adds even more pressure...those factors may have been enough to overwhelm the aging seals and screw up your cylinder...I am putting my money on your master cylinder.
Old Apr 28, 2004 | 11:07 PM
Usfrob22's Avatar
think i could just get away w/replacing the seal or u thinkin im gonna have to get a whole new master cylinder?
Old Apr 28, 2004 | 11:20 PM
Tomservo's Avatar
You know, I don't know....I guess you could have your cylinder rebuilt or something...How much do new master cylinders cost? I know my CLUTCH master cylinder was 60...If I had to guess, I would say replacing the seal is more trouble than it's worth...anyone have any experience with this?
Old Apr 28, 2004 | 11:27 PM
Usfrob22's Avatar
I work at an auto parts store so i can get a decent deal on one, they go about 180 normally i beleive, at 1st i thought maybe i just had an ish load of air in the lines and it would have to be vacuumed out but i mean that hissing/sucking noise is pretty loud so i keep thinkin more and more its lookin like i gotta get a new MC
Old Apr 29, 2004 | 03:07 PM
user 9782082308's Avatar
LOL The mc new is $180! Funny things happen when you remove the brake lines. The same thing has happened to me but its always been that the abs unit needed to be blead.
OttawaGSR
Jul 5, 2011 10:15 PM
black0hatch
16
Feb 17, 2008 12:07 PM
JZA70
Nov 14, 2006 11:16 AM
GSR95T
Sep 4, 2002 09:21 AM
