brake bleeding procedure
Old Feb 29, 2004 | 04:45 PM
PhazedSI's Avatar
Default brake bleeding procedure
I was alawys told when bleeding the whole system to start at the caliper farthest from the master cylender and work your way to the closest. My chilton says the opposite, but for the older gen lude and accord it follows this rule. Any insight?
Old Mar 1, 2004 | 05:39 AM
PhazedSI's Avatar
Default Re: brake bleeding procedure (PhazedSI)
anybody?
Old Mar 1, 2004 | 07:30 AM
trustme's Avatar
i have done many brake fluid flushes and I always started at the furthest away
and worked toward the closest. I have never had a problem in 5 yrs of working
on honda/acura vehicles.
Old Mar 1, 2004 | 07:41 AM
Jagan'92's Avatar
I have always done the bleeding the same way - start at the farthest and work towards the master cylinder. the only reason i can think of for the chilton's to say that (i have one too) is something about the abs. but when you're bleeding, the fluid in the modulator doesn't change, only the fluid in the main tank.
i really don't know, but last time i bled the brakes i did as that manual did and it was no different than starting at the back right wheel.
Old Mar 1, 2004 | 06:12 PM
PhazedSI's Avatar
thanks guys. I know my chilton has been wrong on a few things before.
Chev
14
Oct 20, 2017 03:32 PM
civic_driver
18
May 26, 2010 08:22 AM
DelSol12345
Suspension & Brakes
Nov 10, 2008 05:39 AM
Xxcivic99xX
Oct 26, 2004 06:56 AM
Toda Party
Apr 21, 2002 09:43 PM
