bogging...WOW help!
Old May 15, 2008 | 05:25 PM
bubxba's Avatar
Default bogging...WOW help!
ive did searches and it seems like people are sorta having the same problem but i cant seem to get any help form them, its like i have bad gas, but ive refilled my tank like 4 times since it started, at frist it would do it at about a quarter of a tank till i filled her up agin then it would sorta stop, but now it jsut seems worse, when i drive it and its "driving normal"it still feels like im not getting all my motor power. when its bad, il come outta first and it will sound ok then just bog down, and sound kinda like im still going fast but im not going anywhere, like its not getting gas, but still making the sound. it does this almost every gear when its bad.....sorry this is prolly really hard to amke since to yourself but please try, ill help out as much as i can to solve this problem.
Old May 15, 2008 | 06:01 PM
SikB's Avatar
Default Re: bogging...WOW help! (bubxba)
Years ago when I owned a FI Chevy it would bog like that every 3-6 months. I would then put fuel intector cleaner in it to fix it. I have never had that problem with a Honda but it would be something cheap to try.
Old May 15, 2008 | 06:07 PM
Giant_Bean's Avatar
Default Re: bogging...WOW help! (SikB)
I've been battling a similar issue recently. I have an Iceman intake that I have been running in the short ram configuration, and after driving more than about 15 minutes, the car seems to lose power. After adding the extension into the fender, I havent had a problem, except on the really humid days. So if you have the same problem I do, the issue may be related to high under hood and intake temps( I also have a header which doesn't help). Hope this helps narrow down your problem
Old May 15, 2008 | 07:00 PM
bubxba's Avatar
Default Re: bogging...WOW help! (Giant_Bean)
thanks for the response, this is really stressing me out, im gonna try the fuel injector cleaner and hope for the better im running a sorta cold air intake right now so hopefully thats not the problem, my cel is on right now trhowing a 12, 21, and 23, i can remember which is which but one is vtec solinoide<cant spell>, one is knock sensor and the other is like egc?egr?cgr?idk something like that, could those be cause this?
Old May 16, 2008 | 12:02 AM
bobjohnson's Avatar
I think knock sensor will throw your car into limp mode, which retards the timing. Fix your CEL's.
Old May 16, 2008 | 12:13 AM
no1knows908's Avatar
Default Re: bogging...WOW help! (bobjohnson)
Yea a friends KS went out a few months ago and she said the car bogged like crazy and felt like it had barely any power.
Old May 16, 2008 | 06:52 AM
bubxba's Avatar
Default Re: bogging...WOW help! (no1knows908)
thats def prolly what is it is then. um, can anyone help me out locating the knock sensor, maybe a picture or describe to where its at, cause i cant seems to find a picture anywhere.
Old May 16, 2008 | 03:17 PM
hondabigblock's Avatar
Knock sensor is on the back of the block with one wire coming off of it. take the water temp sensor back off till you can get a new one
EK SQUAD 425
Aug 28, 2007 01:50 AM
bman2033
20
Jun 27, 2006 06:47 PM
94gsr_vtc
Oct 23, 2004 01:41 AM
95civic_d15
Sep 7, 2003 03:47 PM
newt2
May 13, 2002 01:10 PM
