biggest engine in a 92 prelude
Old Aug 13, 2004 | 09:41 PM
bigpoppa15's Avatar
Default biggest engine in a 92 prelude
i was wonderin what the biggest engine that can fit in a prelude is..like can u modify an front wheel drive v6 into it, or will it not fit?...thanx
Old Aug 13, 2004 | 10:00 PM
Freemantle's Avatar
Default Re: biggest engine in a 92 prelude (bigpoppa15)
Well, you could fit an LS1 with the proper tranny if you extended the firewall backwards, fabricated a new crossmember, retrofitted a CR-V driveshaft and differential, trasnferred the shifter, made custom motor mounts with the approppriate tube frame, stand-alone engine management, custom MAP/IACV setup, custom PCV and coolant....
If you have $.
If you don't have money, then the Accord SiR H23 VTEC is the best you'll get.
Old Aug 13, 2004 | 10:05 PM
bigpoppa15's Avatar
Default Re: biggest engine in a 92 prelude (Freemantle)
ok thanx for that info..ye ai dont have that kinda budget..i found a 3.2L accord v6, and was wondering if that would fit?
liability638
Feb 25, 2013 06:46 AM
baselude
Nov 21, 2006 10:27 AM
honda4u2nv
Apr 23, 2005 11:19 AM
bigpoppa15
Aug 15, 2004 06:35 PM
86_accord
Aug 31, 2001 02:59 PM
