bent valve?
Old Oct 10, 2004 | 11:59 AM
Carbon_Lude98's Avatar
Default bent valve?
i think i have a bent valve, will someone tell me a way i can check? or give me the "symptoms" of having a bent valve?
thanks alot
Old Oct 10, 2004 | 12:13 PM
Hawkze_2.3's Avatar
Default Re: bent valve? (Carbon_Lude98)
Compression test or pull and check the head...
Symptoms can be crappy idle, bogging, dying, etc...
Old Oct 10, 2004 | 12:26 PM
LudeyKrus's Avatar
Default Re: bent valve? (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Compression test or pull and check the head...
Symptoms can be crappy idle, bogging, dying, etc...</TD></TR></TABLE>
Yup
Although sometimes just lookin at the valves in the head won't tell you b/c they can get "tweaked" enough so that they don't sit flat in the valve seat, but they look straight.
Do a compression and/or leakdown test.
Old Oct 10, 2004 | 05:14 PM
Default Re: bent valve? (LudeyKrus)
i had a guy tell me that u can hold a dollar in front of ur muffler and if it sucks it twrds the muffler, u have a bent valve...sounds a little crazy..is this true?
Old Oct 10, 2004 | 08:39 PM
SKDRCR's Avatar
Never heard that one, what are your reasons for thinking you have
your valve is bent?
Your best bet is to do a leakdown test.
Old Oct 17, 2004 | 01:17 PM
Uneek4L's Avatar
First off we need to know why you believe you have a bent valve? Rough idle, As well as what engine and when the noise started? The best test to start with is a cylinder leakage test as a compression test will not pinpoint the problem as well. Suspected piston to TDC on the compression/power .. . If you hear air leaking from the carburator or fuel injection intake you have a leaking intake valve. If you hear air out of the exhaust you have a leak past the exhaust valve(s).
-what you have heard about the dollar bill being sucked into the end of an exhaust pipe will pinpoint a burned/leaking exhaust valve each time that cylinder has an intake stroke.
Old Oct 17, 2004 | 03:58 PM
Default Re: bent valve? (Uneek4L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uneek4L &raquo;</TD></TR><TR><TD CLASS="quote">First off we need to know why you believe you have a bent valve? Rough idle, As well as what engine and when the noise started? The best test to start with is a cylinder leakage test as a compression test will not pinpoint the problem as well. Suspected piston to TDC on the compression/power .. . If you hear air leaking from the carburator or fuel injection intake you have a leaking intake valve. If you hear air out of the exhaust you have a leak past the exhaust valve(s).
-what you have heard about the dollar bill being sucked into the end of an exhaust pipe will pinpoint a burned/leaking exhaust valve each time that cylinder has an intake stroke.</TD></TR></TABLE>
ok i think i have a bent valve because i just noticed this rattle or tick in the vavle cover right near the belts. its not really that loud but i dont sound normal.so i figured i had a bent valve.
Old Oct 17, 2004 | 06:05 PM
SuperSlow's Avatar
When is the last time you had an adjustment? If it is that telltale ticking, it is time for an adjust.
Old Oct 17, 2004 | 06:11 PM
951dc5's Avatar
Default Re: bent valve? (SKDRCR)
what is a leakdown test?? is it a compression test alike?
Old Oct 17, 2004 | 08:30 PM
PrettyLude's Avatar
that part of the dollar bill being sucked in the muffler is true when it comes to domestics, but im not too sure about imports
Old Oct 18, 2004 | 06:19 AM
Default Re: bent valve? (Prelude951)
i'll try the adjustment...if that dose not work what else could it be?
SIK IN DA HED
Oct 6, 2017 10:47 PM
moesrex
May 23, 2006 08:55 AM
89sicivic
Feb 2, 2006 08:45 AM
bOOsTiNSoHcVtEc
Nov 1, 2005 02:33 PM
JdmIntegra98
Jul 3, 2003 03:58 PM
