belt dressing
hi i just replaced my belts and its squeaking(only when cold).first question is how do i reach the bottom pulleys so i can spray on them from the side. and second how much dressing should i spray?(the whole can?)
The belts shouldn't be squeaking if they're adjusted properly. You should check and make sure they're not too loose or too tight. And don't waste the whole can... just spray a little at a time.
Mine does the same thing after starting on a cold morning then goes away after a few seconds...
HOWEVER, I live in Maine which is like living in the Artic Circle...and the ONLY Time mine squeals is when its like 0 to -> -15+ F.
I'm guessing in San Fran is more like 30-40 F on a "cold" Morning
so you prob do have some issue...
invisible
Jun 1, 2008 09:38 PM
