Balance shaft re-install
Old May 18, 2009 | 05:13 PM
Specail Ed's Avatar
Default Balance shaft re-install
I tried searching and could not come up with any real answer about re-installing the balance shafts in an H22. And I know, I know, the "cool" thing to do is remove them, but I'm not. Where or how do you set the timing on those shafts without having the head on the motor? The only answers I found were based if you have the head on the motor and just setting the timing on the pulley, not re-installing the shafts and setting the timing. Ay help would be great!
Old May 18, 2009 | 05:24 PM
vinuneuro's Avatar
Default Re: Balance shaft re-install
For the front shaft, there's a hole going through it that you line up with the mark on the block/housing. Look at it and it'll be obvious. For the rear shaft: there's a bolt on the back of the block that you remove. Stick a long bolt through the hole and into the balance shaft to line it up.
If you have a helms look at it, it's made very clear. If not, get one from www.helminc.com
Old May 18, 2009 | 05:28 PM
Specail Ed's Avatar
No helms, only a Haynes which doesn't seem to cover it.
408sbfmustang
Dec 21, 2020 02:51 PM
SpoolinGsx
May 7, 2009 01:49 PM
krayzieboi213
May 29, 2008 10:05 PM
dge330
May 21, 2008 08:56 AM
SPOOLINmatt
May 21, 2004 05:36 AM
