Bad TPS sensor??
Old Jun 12, 2008 | 10:11 PM
Thatssojdm's Avatar
Default Bad TPS sensor??
so my car has been miss firing lately aroud 2k rpm and it has a very weird iddle when it first warms up and as soon as get of the freeway it starts up again. we checked my plug, distirbutor, wires, everything is good. could it be just the TPS gooing bad?
Old Jun 12, 2008 | 11:16 PM
Hawkze_2.3's Avatar
Default Re: Bad TPS sensor?? (Thatssojdm)
It could be....but then it might not be. Check the voltage.
Old Jun 13, 2008 | 04:19 AM
ludecraze93's Avatar
a bad TPS sensor wouldnt be an intermittent problem it'd be all the time.
Old Jun 13, 2008 | 07:09 AM
Thatssojdm's Avatar
Default Re: Bad TPS sensor?? (ludecraze93)
could it be going bad? thats why?
Old Jun 13, 2008 | 07:43 AM
TPS wouldnt cause a misfire though itd cause you to have no throttle.
Old Jun 13, 2008 | 07:45 AM
im dealing with a misfiring issue right now too.
but id check your coil and your alternator make sure its putting out the right voltage providing the ignition with the proper amount of current to supply spark.
Old Jun 13, 2008 | 11:34 AM
Thatssojdm's Avatar
what are you dealing with?
Old Jun 13, 2008 | 05:09 PM
https://honda-tech.com/zerothread/2321041
8600RPM
Nov 11, 2011 03:23 PM
geogal84
Oct 23, 2007 02:41 PM
SIK IN DA HED
Nov 21, 2002 03:21 PM
