axle help!!
Old Jul 18, 2004 | 08:24 PM
killa_lude's Avatar
Default axle help!!
i have a 93 prelude, and i cant get the damn cv joint into the intermediate shaft!!! i cant pull off the hub bolt, because its rusted on. right now im trying to pound it in, with the axle still in the cv joint. i just have to pound it in enough so it will click into the ring. can some one help me!!??
Old Jul 18, 2004 | 09:24 PM
Speedra500's Avatar
Default Re: axle help!! (killa_lude)
the way i got those spindle nuts off was buy take out the centercaps in the wheels and put the car in gear and lower it back down and i got my breaker bar w/ a 3ft cheater bar and pulled hard and that did the trick... and they were very rusted on
Old Jul 18, 2004 | 11:42 PM
killa_lude's Avatar
Default Re: axle help!! (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">the way i got those spindle nuts off was buy take out the centercaps in the wheels and put the car in gear and lower it back down and i got my breaker bar w/ a 3ft cheater bar and pulled hard and that did the trick... and they were very rusted on</TD></TR></TABLE>
yeah we cant get the nut off, so i want to try to get it in with the axle still in.
Old Jul 19, 2004 | 05:44 AM
OTT's Avatar
OTT
do you mean the intermediate shaft into the CV sliding tripod joint? if you do then I would suggest turing the circlip that is on the intermediate shaft around so that the gap in the circlip is facing down. I find that it makes it alot easier. Oh, also watchout you dont tear the CV boot even slightly, its so easy to do and will cause you so many problems.
Old Jul 19, 2004 | 09:10 AM
killa_lude's Avatar
Default Re: axle help!! (OTT)
ok i will make sure the ring gap is facing down. yeah the boot is removed right now.
Old Jul 19, 2004 | 02:51 PM
user 9782082308's Avatar
I was literally bouncing on a breaker bar to get that nut off! As for the intermidiate shaft, the fsm says to hit it with a hammer. Thats just dumb unless you remove the cradle cause you can't get a good angle on it. I took a bunch of 3/8" ratchet extensions, went over the cradle and then hit it with a hammer. Works much better that way.
Old Jul 19, 2004 | 04:46 PM
killa_lude's Avatar
Default Re: axle help!! (racerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx &raquo;</TD></TR><TR><TD CLASS="quote">I was literally bouncing on a breaker bar to get that nut off! As for the intermidiate shaft, the fsm says to hit it with a hammer. Thats just dumb unless you remove the cradle cause you can't get a good angle on it. I took a bunch of 3/8" ratchet extensions, went over the cradle and then hit it with a hammer. Works much better that way.</TD></TR></TABLE>
hmm where did you end up hitting the cv joint to get it in?
Old Jul 20, 2004 | 02:22 PM
You mean where did I hit it to get it back on the intermidiate shaft? No problems getting it back on, it just slid on.
Old Jul 20, 2004 | 04:13 PM
killa_lude's Avatar
i got the axle nut off, and i can hit the axle all the way so its flush with the rotor, but it still didnt snap in. so do i have to take off the rotor and hit it?
Old Jul 20, 2004 | 04:15 PM
Hit it with a 3/8" extension.
Old Jul 20, 2004 | 07:26 PM
killa_lude's Avatar
ok i'll try that.
brodyl05
Suspension & Brakes
73
Jun 27, 2007 07:38 AM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
JDM_EK_JOE
Jan 23, 2006 06:06 PM
B17CRXracer
34
Jun 19, 2005 11:13 PM
gsrcivic619
10
Jan 5, 2004 04:07 PM
