automatic to manual conversion prelude si
I need to know what parts I need left to do it I have: clutch kit, manual pedal, stick shifter assembly with mounting brackets and lines, stainless steel clutch line, slave/master cylinder, accord tranny, and ecu.
What I am really stuck on although is what I need to put the clutch pedal in itself and will I need a brake pedal with it along with a manual transmission key starter.
You need two nuts and on bolt for the top for the clutch pedal assembly, i used a jdm clutch pedal assembly so i had to put spacers in between the assembly and fire wall. I dont know if the usdm pedal assembly requires this or not. Yes you need the 5spd starter a usdm brake pedal. Good luck
xduB95preludeSi
Jul 25, 2014 12:32 AM
Midori Green
13
Dec 6, 2006 04:56 PM
Phat_Jax
Sep 6, 2004 08:28 PM
