auto tensioner problem..HELP
Old Apr 9, 2005 | 02:34 PM
HOLDEM1981's Avatar
Default auto tensioner problem..HELP
I've got everything in time and every thing looks good, BUT I can not get the tensioner back compressed to get it back in under the tensioner roller please please help.
Old Apr 9, 2005 | 02:50 PM
HOLDEM1981's Avatar
Default Re: auto tensioner problem..HELP (HOLDEM1981)
somebody???? Come on guys I know someone has changed their timing belt before.LOL
Old Apr 9, 2005 | 06:49 PM
MackDad's Avatar
Put it in a vice between two peices of wood, or some form of material that is softer than the tensioner and wrap a good size zip tie around it before compressing. Once it's compressed then tighten the tie...
Old Apr 10, 2005 | 02:02 AM
Honda Sport's Avatar
you're in luck, I just did my timing belt a few days ago. anyways, you need to take off the maintenece bolt(8mm bolt) off the bottom of the auto-tensioner. look inside and you'll see that you need a flat head screw driver to turn the bolt inside. once you turn it, it'll compress. and as what MackDad said, use a zip tie to hold it down until you bolt it back onto the block or go buy the stopper from honda.
Old Apr 10, 2005 | 11:51 AM
FRANKO_89's Avatar
YEAH U CANT COMPRESS IT AGAIN I JUST DID MINE N U HAVE TO BUY A NEW ONE OR YOUR TIMING BELT WILL BE WAY TO TIME AND EVENTUALLY SNAP THEN U R SCREWED
FRANKO_89's Avatar
WAY TO TIGHT* SORRY
Old Apr 10, 2005 | 09:05 PM
Default Re: (FRANKO_89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANKO_89 &raquo;</TD></TR><TR><TD CLASS="quote">YEAH U CANT COMPRESS IT AGAIN I JUST DID MINE N U HAVE TO BUY A NEW ONE OR YOUR TIMING BELT WILL BE WAY TO TIME AND EVENTUALLY SNAP THEN U R SCREWED</TD></TR></TABLE>
actually you CAN compress it. I just did my timing belt a few days ago. re-read my post before yours and you'll get what I mean.
Old Apr 10, 2005 | 09:53 PM
PrettyLude's Avatar
you can compress it by undoing the screw on the bottom and turning the screw inside, it should compress
i would not reuse that tensioner, i have seen alot of autotensioners fail because they reused
i might suggest doing the h23 manual tensioner conversion
Old Apr 11, 2005 | 05:42 AM
IHateJDM's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you can compress it by undoing the screw on the bottom and turning the screw inside, it should compress
i might suggest doing the h23 manual tensioner conversion</TD></TR></TABLE>
One of mine broke when turning the screw inside the tensioner, all the hydraulic fluid leaked out. I bought another one, and when I was doing my timing belt again, I had to re-compress it. This time nothing leaked out, and it looked like it was working. It gave out about a week later. I highly recomment the manual tensioner conversion.
Old Apr 11, 2005 | 06:23 AM
PrettyLude's Avatar
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">One of mine broke when turning the screw inside the tensioner, all the hydraulic fluid leaked out. I bought another one, and when I was doing my timing belt again, I had to re-compress it. This time nothing leaked out, and it looked like it was working. It gave out about a week later. I highly recomment the manual tensioner conversion. </TD></TR></TABLE>
sorry to hear that man
Old Apr 11, 2005 | 06:48 AM
IHateJDM's Avatar
sorry to hear that man</TD></TR></TABLE>
It's no big deal, my motor survived. I just recommend the manual tensioner because the auto tensioner is known to fail, and when your timing belt goes, its a 50 - 50 shot your motor will be fucked.
Old Apr 11, 2005 | 07:14 AM
PrettyLude's Avatar
did u bend any valves
Old Apr 11, 2005 | 07:20 AM
IHateJDM's Avatar
nope, i got lucky. it came off at about 2500 rpm's. I'm just glad it didn't come off at 7k. IMO the auto tensioner is a piece of ****. Do the conversion, you'll be happy you did.
Old Apr 12, 2005 | 03:34 PM
HOLDEM1981's Avatar
THANKS FOR ALL THE HELP GUYS!!!
methos713
May 5, 2008 08:01 PM
asdfsad
Apr 1, 2006 08:23 AM
del_orson
Mar 10, 2005 06:37 AM
slipperyduck
Jun 11, 2004 10:07 PM
Yuleluder
Jul 29, 2002 12:20 PM
