ATTS Light Reset- Failed
Old Oct 4, 2009 | 02:59 PM
Bascotie's Avatar
Default ATTS Light Reset- Failed
Hey guys,
I tried the instructions from the Helms manual (as well as the sticky we have on CEL, ATTS codes) on resetting the ATTS light so I can perform an ATTS function test.
The problem is I was getting code 78 (ATTS Control Unit) and according to the service manual I was suppose to reset the code before troubleshooting it further.
I tried to reset it a few times and it failed everytime.
Parking brake was up, tires were straight forward, i had a paperclip in the blue connector. Went to ON position, once I saw the ATTS light come on immediately I turned the wheel to the right one full turn, then back as soon as I saw it go off but it just kept coming back and telling me the code.
When I turn on the car, the ATTS light DOES turn off like it normally should, should I be concerned or wait for it to come back on?
Old Oct 4, 2009 | 03:14 PM
vinuneuro's Avatar
Default Re: ATTS Light Reset- Failed
That never worked for me either. Just pull the clock/radio fuse in the undehood fuse box as you would to reset a cel.
Old Oct 4, 2009 | 03:17 PM
Bascotie's Avatar
Is this suppose to work for ATTS? I think they have different instructions depending on what kind of code you want to reset.
Old Oct 4, 2009 | 03:32 PM
vinuneuro's Avatar
It 'should' since it's in the helms. But why even bother. It's a lot more tedious than just pulling the clock/radio fuse to reset.
Old Oct 4, 2009 | 03:34 PM
Bascotie's Avatar
Well I didn't want to reset the radio code yet I have to contact Honda customer service and put the car under my name before I can retrieve the code free online
Old Oct 5, 2009 | 01:14 PM
Kronn 98SH's Avatar
I've gotten it to work, but it took 3 tries. It's all in the timing.
And pulling the clock/radio fuse didn't clear my ATTS codes.
Old Oct 5, 2009 | 03:17 PM
Bascotie's Avatar
So do you start turning the wheel as soon as you turn to the ON position and see all the lights on the dash come on (including ATTS)? Or do you wait until the next time the ATTS light shows?
Old Oct 5, 2009 | 05:19 PM
gstrudler's Avatar
Should be the next time, iirc. The light will come on with all the dash lights, then turn off, then turn on again. Then you turn the wheel, it goes off, then you straighten, it goes on, etc.
Old Oct 5, 2009 | 08:54 PM
Bascotie's Avatar
I see. Weird though, when I turn the wheel its like the light ignores that im turning it and just keeps going through the normal blinking cycles. It is very difficult to turn the wheel being only in "ON" mode lol
Old Oct 5, 2009 | 09:18 PM
Kronn 98SH's Avatar
You have to turn the wheel quickly. Turn it 45º and then back to center before it blinks the second time. Then repeat. The first two times I did it, I didn't turn the wheel fast enough.
Old Oct 6, 2009 | 01:01 PM
Bascotie's Avatar
I might have to lift the front to be able to turn the wheels quicker.
Old Oct 6, 2009 | 01:50 PM
Kronn 98SH's Avatar
Dude, i'm 125lbs and I can turn the wheel. Besides, 45º of the steering wheel equates to almost nothing for the front wheels.
Old Oct 6, 2009 | 02:47 PM
Bascotie's Avatar
Maybe I am turning too far then, because the car is off its like turning the wheel without power steering and to be safe I was trying 1.5 rotations before going back.
Old Oct 6, 2009 | 02:58 PM
Kronn 98SH's Avatar
Uhhh....no, don't do that. 45º is all you need, and that's what is stated in the instructions.
Old Oct 6, 2009 | 03:48 PM
Bascotie's Avatar
I just turned it that much because I figured it didnt move too much each full turn, I didnt think id end up being at 90 degrees haha
Old Oct 9, 2009 | 11:01 AM
dans4's Avatar
the next time it goes back on it starts to read off the codes.
Ive tried about 50 times. Still no luck.
Old Oct 9, 2009 | 02:22 PM
Kronn 98SH's Avatar
I hope you're following the directions properly.
Step 1: Connect the jumper.
Step 2: Pull the ebrake up far, not just 1 or 2 clicks. Pull it up the same amount as if you were parking on a hill in neutral.
Step 3: Make sure your wheels are pointed straight ahead.
Step 4: Turn the ignition to ON (do NOT start the car).
Step 5: Wait for the ATTS light to blink once. As soon as it does, turn the steering wheel 45º to the right. For the geometrically challanged, 45º is half of 90º. That means if you typically hold your hands at 10 and 2, they should be at 11:30 and 3:30 after a 45º right turn.
Step 6: When the ATTS light goes off, QUICKLY return the steering wheel to straight ahead position.
Step 7: Wait for the ATTS light to again. As soon as it does, turn the steering wheel 45º to the right. For the geometrically challanged, 45º is half of 90º. That means if you typically hold your hands at 10 and 2, they should be at 11:30 and 3:30 after a 45º right turn.
Step 8: When the ATTS light goes off, QUICKLY return the steering wheel to straight ahead position.
The light should pause for about 2 seconds. Then you should get 2 short blinks and nothing else.
Try it again EXACTLY as I have described. If you still can't get it, drive the car to me and I'll reset it for you. I will only charge a small fee of $50.
Old Oct 9, 2009 | 03:42 PM
dans4's Avatar
my video was here
Old Oct 9, 2009 | 04:23 PM
Kronn 98SH's Avatar
I had to watch that video probably six times just to see your timing. Try again in the daylight with the camera having the correct orientation. I'll be able to tell you what you're doing wrong, if anything.
Old Oct 9, 2009 | 05:00 PM
Bascotie's Avatar
LOL @ dans video (never pulled the brake up that far before hahahaha)
Anyway. I think the confusion for me was turning the "WHEELS" 45 degrees rather than turning the "Steering wheel" 45 degrees. I'll try this again and let you guys know if that works then explain.
Old Oct 9, 2009 | 05:01 PM
dans4's Avatar
ok sounds good thanks for thew help
Old Oct 9, 2009 | 05:18 PM
Bascotie's Avatar
Ok just did it, its a lot easier when you realize you only need to turn the steering 45 degrees and not the wheels themselves LOL
1) Plug in connector, make sure its in the bottom two holes which are smaller (the blue connector should have 4 little square holes where it looks like you can connect the paperclip or whatever youre using to, its the two smaller ones)
2) Handbrake up
3) The FIRST time you see the ATTS light come on which is almost immediately after you turn to the ON position turn the wheel slightly to the right, not even half way down.
4) Hold it there and once the light goes off turn the wheel back up so the wheels would be pointing straight.
5) It's gonna come on very shortly after that where you turn the steering wheel to the right to about 2 o clock again and wait for the light to go off.
6) Now turn back to 12 o clock and the light should go off and stay off after that.
You'll know its working because the light takes a little longer to turn off after you go to the 2 o' clock position the first time.
Good luck ill try and make a video when im not so busy!
Old Oct 10, 2009 | 08:18 AM
dans4's Avatar
thats key i had to move steering wheel asap after key was turned.
thanks again for your help.
Old Oct 10, 2009 | 09:40 AM
Bascotie's Avatar
Did it work?
Old Oct 10, 2009 | 03:32 PM
dans4's Avatar
Yes but it would only reset the one code. I still have a code 61
