apexi turbo timer
i have a apexi turbo timer on my 95 honda prelude and everything works but when i try to take the key out the timer will shut off it will start counting down when its in the number 1 postion but when you turn the key back towards you to the 0 positon the timer will go off and not stay on with the key out of the ignition the key has to be in the 1 position and the timer will count down but you cant pull the key out thanks any help would be great and yes everything is hooked up right i promiss thanks
