Acceleration Question
My 1999 prelude is shakey when accelerating all the way up until 4th gear. It's not quite smooth. I replaced the plugs and wires with factory ones about a week ago and also have a facotry fuel filter that still needs to be replaced. Could this be the cause? Or is there something else causing a shakey acceleration?
thanks
thanks
bad axles, bad balljoints, bad tierod ends, bad alignment, bad wheel bearings, bad tires, bent rims, low tire pressure, bad struts, bad bushings, and anything engine related
^can all cause this
^can all cause this
