ABS sensor search
Old May 1, 2006 | 09:01 AM
The_Sober's Avatar
Default ABS sensor search
My ABS light came on a while ago and I'd like to see if there's a way to find out which sensor is faulty without having to take off my wheels and check 'em one at a time.
Anybody know?
Old May 1, 2006 | 11:59 AM
ludeDVR's Avatar
Default Re: ABS sensor search (The_Sober)
Jump the harness just like when you jump the CEL. It'll blink and check it with the error codes in the helms.
Old May 1, 2006 | 12:08 PM
syntax.'s Avatar
the only way to see whats wrong is to check the abs code, like mentioned above. there really isnt anything to visually inspect on the wheel speed sensors anyways. Also be prepared for the fact that it could be something much worse than just a faulty wheel speed sensor, it could be pump motor overrun, modulator failure, etc.
But if it is a wheel speed sensor ill sell you one cheep
Old May 1, 2006 | 12:42 PM
The_Sober's Avatar
Default Re: ABS sensor search (sYn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sYn &raquo;</TD></TR><TR><TD CLASS="quote">But if it is a wheel speed sensor ill sell you one cheep </TD></TR></TABLE>
I'll definitely keep that in mind.
However, I don't know how to <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeDVR &raquo;</TD></TR><TR><TD CLASS="quote">Jump the harness.</TD></TR></TABLE>
Any suggestions would be appreciated.
Old May 2, 2006 | 10:21 AM
syntax.'s Avatar
do you know how to pull cel codes? same thing.
Progen
Dec 27, 2013 02:26 AM
HondaHeddie
Sep 29, 2008 08:02 AM
96teggynonVtec
Jan 23, 2007 01:32 PM
dreams190
Apr 24, 2006 07:16 PM
JLange
Mar 12, 2003 06:03 AM
