abs light
Old Aug 31, 2005 | 02:37 PM
Lude454's Avatar
Default abs light
I had work done to my axels last week and the passanger side abs connector had to be disconnected. now when i go for a drive no more than 2 mins in to the drive the brakes fell funny and the abs light comes on. i am driving a 2000 prelude sh any ideas on what is causing the problem
Old Aug 31, 2005 | 03:05 PM
prelude1897's Avatar
Default Re: abs light (Lude454)
What kind of work did you have to do in order to have to disconnect your ABS sensor? You may have messed up the sensor whenever you disconnected it
Old Aug 31, 2005 | 03:21 PM
Lude454's Avatar
Default Re: abs light (prelude1897)
i had to relpace the trans seal but me and my bud had problems with the axel and the axel nut someone before me tightened it to tight and when my bud was takeing it off it struped the axle nut and some of the treades on the axle we retreded the axle and put a new nut on but the reason we had to disonnect the abs was because after we got the nut off the axle we could not get the axle out the ( don't know what it is called the part were the axle comes out through the rotor) that is way every thing was disconnected to do the trans seal
Old Aug 31, 2005 | 07:43 PM
Lude454's Avatar
bump
someone must know
Old Aug 31, 2005 | 08:04 PM
IIVIIoOkY's Avatar
yeah dude id like to know as well. i have a 97 lude and my abs light actually always stays on. i have to replace my bearings on my 2 rear tires. my uncle has his own garage and we checked it out and nothing seemed wrong, even the honda dealer said everything was fine. i think its just a messed up sensor hopefully lol
Old Sep 1, 2005 | 12:46 AM
Lude454's Avatar
Default Re: abs light (xLude97)
bump i need a answer
Old Sep 1, 2005 | 03:35 AM
syntax.'s Avatar
sounds like a bad wheel speed sensor.
you can pull the abs code just like you would a cel. that should point you in the right direction.
GraphiteMW
Mar 5, 2007 05:04 PM
kurijli
Feb 5, 2007 07:39 AM
Ideal
Apr 24, 2005 08:12 PM
clemsonhatch
Jan 2, 2005 03:13 PM
djmatix
Feb 12, 2004 09:33 PM
