97+ vtec in 95?
Old Jul 20, 2003 | 06:33 PM
cherns's Avatar
Default 97+ vtec in 95?
Can you put a newer vtec engine 97+ into a 95 s? I want the newer style b/c they they more hp? Would this swap work?
Old Jul 20, 2003 | 07:06 PM
imported204's Avatar
Default Re: 97+ vtec in 95? (cherns)
youd be better off getting a JDM h22
Old Jul 20, 2003 | 07:59 PM
sslude's Avatar
Default Re: 97+ vtec in 95? (imported204)
yes you can. yes, they do have more hp.
Old Jul 20, 2003 | 08:39 PM
PetroGuyX's Avatar
Default Re: 97+ vtec in 95? (sslude)
h22a4's have more hp than h22a1's?? i had no idea, they're both rated at 190 correct?
Old Jul 20, 2003 | 08:42 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sslude &raquo;</TD></TR><TR><TD CLASS="quote">yes you can. yes, they do have more hp. </TD></TR></TABLE>
You're on crack...it's well known the numbers were just made up...the prelude kept the same hp ratings in Japan from 1991-2001 for the h22a...
You can put a 97 into a 95 you will just have to redo some wiring on the distributor...the CKP sensor moved from the dist to the oil pump in 1996 (OBDII)
Old Jul 20, 2003 | 08:48 PM
Cottonwoodz's Avatar
Old Jul 21, 2003 | 08:22 AM
CHK4TIX's Avatar
Default Re: 97+ vtec in 95? (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Jul 21, 2003 | 12:09 PM
cherns's Avatar
so even though tI have seen sites that say the new preludes have 195, or 200 hp they really don't,?
Old Jul 21, 2003 | 05:59 PM
Teen Heartthrob's Avatar
Default Re: (cherns)
i wouldnt bother with an h22a4, the h22a1 has slightly better gearing. yes, i am biased, but i have driven both 4th and 5th gens quite often.
Old Jul 21, 2003 | 06:07 PM
PetroGuyX's Avatar
the SH is the only prelude rated at 195, the JDM prelude was rated at 197 and the base prelude 5th gen and prelude vtec 4th gen were both rated at 190
Old Jul 23, 2003 | 02:16 PM
satan_srv's Avatar
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">the SH is the only prelude rated at 195, the JDM prelude was rated at 197 and the base prelude 5th gen and prelude vtec 4th gen were both rated at 190</TD></TR></TABLE>
you're on crack too...
All JDM preludes (non type-s): 200ps = 197hp
UDSM
93-96 VTEC = 190hp
97-98 = 195hp (Base and SH), 190hp (SS)
99+ = 200hp (Base and SH), 195hp (SS)
And at the end of the day we are talking about max 10 flywheel hp that likely doesn't exist.
Get a JDM, higher compression, more power.
Old Jul 25, 2003 | 08:12 PM
PetroGuyX's Avatar
i don't get it... how was i wrong? lol
Old Jul 25, 2003 | 08:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">i don't get it... how was i wrong? lol</TD></TR></TABLE>
Cause you just are.. SH's and base 97+ ludes had the same Hp depending on year. Auto ludes were always rated 5 Hp lower then manuals ludes of them years.
Old Jul 25, 2003 | 08:46 PM
sslude's Avatar
Default Re: (Cottonwoodz)
hold on, i thought he was talking about prelude S. arent they like 145 hp?
j00clown
Jul 7, 2007 09:05 PM
yellow_jacket
May 12, 2004 02:24 PM
Hellish Elf
32
Aug 4, 2003 08:33 AM
