95 Prelude AC Problem
Old Apr 20, 2006 | 03:02 PM
pgold21's Avatar
Default 95 Prelude AC Problem
My 1995 SE is finally starting to show some wear. My A/C is no longer turning on when I want it to. With the fan on, I push the A/C button and nothing. No green light, no cold air. The only solution seems to be hitting the dash near the button/vents. This used to work really well but now not so much. Any idea how much it would cost to get the work done? IS it tough to get to myself? Could I replace the switch or whatever with some scrwdrivers and nut drivers? Anyone else out there experience the same problem with their Prelude? Any ideas on how to fix it? Thanks in advance.
Old Apr 20, 2006 | 06:37 PM
Slatelude's Avatar
Default Re: 95 Prelude AC Problem (pgold21)
theres some info/links on here that should solve your problem...its not just you, it happens to the best of us.
K
Old Apr 20, 2006 | 06:47 PM
pgold21's Avatar
Default Re: 95 Prelude AC Problem (Slatelude)
I did a search for Prelude AC and air conditioning and found nothing. Sorry to be so lazy but could you give me another hint to set me in the right direction? Thanks.
Old Apr 20, 2006 | 07:20 PM
Slatelude's Avatar
sorry actually meant to post this....it is just like halfway down the page:
https://honda-tech.com/zerothread/1600014
K
Old Apr 23, 2006 | 10:07 PM
pgold21's Avatar
I did the soldering repair but now all the lights for the climae control section don't work. I mean the ones that turn on when you turn on the headdlights. Do those little bulbs have a certain way they need to be installed? I know I dropped one and it looks like the filament broke. I'm going to order new ones from the dealer but I don't want to burn them out installing them the wrong way. Is there a wrong way or just insert and turn. I noticed a S and U on the the back of the bulb. Is this like + / - for installation or just put in any which way?
tigershark
Jun 11, 2008 01:19 PM
int3gra07
May 30, 2007 12:59 PM
SiR AuToBoT
May 7, 2007 10:45 PM
twitwaic
Jul 4, 2006 08:37 PM
rscouten1234
Aug 9, 2005 01:32 PM
