88 Prelude
Old Nov 2, 2011 | 09:40 AM
Sunrise21Motors's Avatar
Default 88 Prelude
Seat belt / Door light comes on and starts beeping out of no where, doors are closed and seat belt is fastened..loose connection somewhere?
any help?
Old Nov 5, 2011 | 11:52 PM
1funryd's Avatar
Default Re: 88 Prelude
any help?
Its your seabelt sensor. Its not working proplery. Unfortunately there is no new replacement parts for that, so you will need to go to a junkyard to pull a used sensor and replace it.
Or you can check to see if Honda can still get it, but more than likely its a discontinued part.
Old Nov 6, 2011 | 05:19 PM
TheJGB3's Avatar
Since seat belts have a LIFETIME warranty, the buckle is still available
http://www.hondapartsnow.com/genuine...SF1-A02ZB.html $45.59
#18 in the parts exploded view
Old Nov 7, 2011 | 09:53 PM
1funryd's Avatar
Yes it is a guaranteed part, and from the more recent memebers on pp.com those parts are getting low.
I believe that the graphite color is no longer available.
But they had the dark brown color. Like I said earlier, just check with your local Honda dealer for availability.
Old Nov 8, 2011 | 03:52 PM
92civlude's Avatar
The door switch in the latch may have failed. If this is the case, whole door latch assy must be replaced. Its easy to test. Its the 3 pin connector behind the door panel near the latch. Check continuity between the center wire of the connector to each outside wire. There should be 0 ohms (continuity) on respective wires with the latch open and closed.
deving916
68
Mar 28, 2012 04:23 PM
mhmmofr0
Honda Civic (2001 - 2005)
Feb 9, 2010 03:55 AM
CRXguy_88
Jan 14, 2010 09:43 PM
sxthirteen
Honda Civic (2006 - 2015)
12
Sep 18, 2006 12:33 PM
Nizzy
Aug 24, 2004 07:41 PM
