5th gen Polyurethane engine mounts?
Old May 14, 2005 | 08:39 AM
K-Spec's Avatar
Default 5th gen Polyurethane engine mounts?
I've searched in the archives, but couldn't find a concrete answer. So I was wondering if anyone knows where I can find polyurethane engine mounts for the 5th gen? Or who would make such a product?
Old May 14, 2005 | 08:43 AM
BlackLudeSi's Avatar
Default Re: 5th gen Polyurethane engine mounts? (khalal538)
Prothane poly bushing and Suspension Techs. both make kits, we're a supplier of them if you can't find them else where, shouldn't be too much, i payed 28 for mine (4th gen) Keep in mind these are just inserts, if you want actual mounts expect to pay way more
Old May 14, 2005 | 08:48 AM
98vtec's Avatar
moderator emeritus
Default Re: 5th gen Polyurethane engine mounts? (BlackLudeSi)
energy suspension
Old May 14, 2005 | 10:37 AM
K-Spec's Avatar
Well, the thing is I'm doing a manual tranny swap (auto to 5spd) and it turns out I need a new tranny mount because I cannot use the stock one. So I thought if I was going to change one tranny mount, why not change all the other mounts so I can save the labor and time. Now, for the poly inserts, am I able to use my stock mounts and all I would have to do is change the inserts? And how much can you sell me the inserts for? (I have a 5th gen)
Old May 14, 2005 | 10:40 AM
K-Spec's Avatar
Default Re: 5th gen Polyurethane engine mounts? (98vtec)
I checked energy suspensions and I think they only make it for the 4th gen. Do you know if the one for the 4th gen will fit my 5th gen?
Old May 14, 2005 | 10:52 AM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">Well, the thing is I'm doing a manual tranny swap (auto to 5spd) and it turns out I need a new tranny mount because I cannot use the stock one. So I thought if I was going to change one tranny mount, why not change all the other mounts so I can save the labor and time. Now, for the poly inserts, am I able to use my stock mounts and all I would have to do is change the inserts? And how much can you sell me the inserts for? (I have a 5th gen) </TD></TR></TABLE>
You don't need new engine mount for tranny!!! All you need is the 5g manual tranny mount BRACKET. The mount is stuck on the body already, and the mount bracket will be bolted on the tranny. The bracket will go over the mount and will be held by one long bolt. I did the swap on my '99, trust me.
Old May 14, 2005 | 06:05 PM
BB4's Avatar
BB4
check the sponsors section, i jsut got some froma s ponsor for $36? shipped
Old May 15, 2005 | 12:58 AM
K-Spec's Avatar
Default Re: 5th gen Polyurethane engine mounts? (xbn83)
Ok, but should I change the inserts to poly while I swap my tranny anyway?
Old May 15, 2005 | 03:49 AM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, but should I change the inserts to poly while I swap my tranny anyway?</TD></TR></TABLE>
I did not change anything while swapping the tranny. I think the mounts on 5 gen are all pretty good already.
Old May 15, 2005 | 07:50 AM
nubs's Avatar
Get the suspension techniques inserts...... Best investment I ever made. huge difference
Old May 15, 2005 | 08:13 AM
K-Spec's Avatar
Default Re: 5th gen Polyurethane engine mounts? (nubs)
How much are the suspension techniques inserts? And is it hard to install just the inserts?
Old May 15, 2005 | 08:28 AM
fastludeh22's Avatar
http://importnut.net/motormount.htm or
http://www.homemadeturbo.com/t...ounts/
MugenHonda
Aug 10, 2007 12:13 PM
kornerk12
May 19, 2007 02:06 PM
Innovation
Apr 4, 2007 05:17 AM
pinecone
Apr 3, 2007 08:32 AM
2000Accord5sp
Apr 23, 2003 09:41 PM
