1998 Prelude stalling???
Old Aug 22, 2008 | 09:56 AM
luder916's Avatar
Default 1998 Prelude stalling???
I have a 98 lude, engine never been modified. I had the clutch, timing, water pump and all other belts changed. My problem is that sometimes when I come to a stop the car would die. I dont know whats going on so I changed the alternator but the problem is still there. Not all the time but just some of the time. Its still rides like new and I love the car.
Thanks ahead of time.
Old Aug 22, 2008 | 07:43 PM
vtecb18c's Avatar
Default Re: 1998 Prelude stalling??? (luder916)
clean your IACV(idle air control valve)...or changing your Throttle position sensor
Old Aug 22, 2008 | 07:46 PM
Saosinx's Avatar
Default Re: 1998 Prelude stalling??? (vtecb18c)
might be a shot in the dark but when did you last set your timing?
Old Aug 22, 2008 | 07:55 PM
vtecb18c's Avatar
Default Re: 1998 Prelude stalling??? (Saosinx)
i was thinking timing but he said it only happens sometimes so i would think that would cancel that out
Old Aug 23, 2008 | 10:07 AM
REDLUDE4WS's Avatar
timing? iacv? tps? huh? does the car start back up ie have power, crank over? from your explanation pretty tough. mo info yo.
Old Aug 23, 2008 | 11:55 AM
vtecb18c's Avatar
Default Re: 1998 Prelude stalling??? (REDLUDE4WS)
Edited:thought it was OP
Modified by vtecb18c at 5:18 PM 8/23/2008
Old Aug 23, 2008 | 11:58 AM
Giant_Bean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">ummm.......ok take it to a shop and have them look at it...trust me ...we just gave you info and you have NO idea what were talking about so take it to someone who does...just my opinion</TD></TR></TABLE>
ummm...The OP hasn't even replied to anything yet.
Old Aug 23, 2008 | 01:31 PM
luder916's Avatar
Yea the car starts back up after it cuts off. I dont know what the prob is but i will try to clean the IACV or maybe change the trottle position sensor.
Old Aug 27, 2008 | 08:35 AM
REDLUDE4WS's Avatar
Default Re: (luder916)
don't touch the tps unless there is a code and out of spec. spray your cap and wires down with water and put car under light load ie. try to go forward (use ebrake if you want). see if it dies.
Old Aug 28, 2008 | 07:52 AM
luder916's Avatar
It doesnt die, the car is good just sometimes it dies on me, i.e. when coming to a stop at a light or sign it would just die like it wasnt getting enough fuel or air. I havent had time to check it out yet but hopefully this weekend will be the one.
Old Aug 28, 2008 | 08:04 AM
97ludedude's Avatar
x2 idle air control valve. pull it off clean all the carbon off and drive. see if it still does it. i would almost put money on it.
Old Aug 28, 2008 | 09:20 AM
luder916's Avatar
Do anyone have a pix of what that part looks like? I dont have a prob taking it off but just want to know what it looks like.
Old Aug 28, 2008 | 01:15 PM
gstrudler's Avatar
Don't have a pic, but it's a small-ish piece in the middle on the front of the intake manifold with an electrical connector and two rubber (coolant) lines going to it. I think it just has two bolts holding it on. Try cleaning that out and also check the idle adjusting screw on the throttle body and try opening it up a little. In fact, try unplugging your IACV once the car is warmed up and see if it dies.
Old Aug 29, 2008 | 10:23 AM
shah2105's Avatar
Hi luder916
I had a similar experience with my lude,
It could be your ignition switch, that was the problem with mine.
You can test it by turning the key to start engine normally but let it go quickly as the key springs back almost helping it to cut out.
Usually if the ignition switch is good than the engine will not cut out.
I hope this helps and of course this may not be whats wrong.
Good luck!
Old Aug 29, 2008 | 12:32 PM
luder916's Avatar
Thanks I will try.
FlyingDaggers
Mar 16, 2008 11:35 AM
h22crazy07
May 2, 2007 03:43 PM
gridelock
Mar 21, 2005 01:22 AM
preludetos2kupgrade
Aug 25, 2004 08:04 AM
