Wheel compatibilty
Are rims some what compatible with other makes and models, I found a nice set of powdercoated rims off a CBR f3 ,was curious if it would work on a Kawasaki Zx7R What would be some of the noteable differences? Is there a certain size scale to go by? Any help is greatly appreciated- James
Modified by civiccrx21 at 7:52 AM 10/18/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccrx21 »</TD></TR><TR><TD CLASS="quote">Are rims some what compatible with other makes and models, I found a nice set of powdercoated rims off a CBR f3 ,was curious if it would work on a Kawasaki Zx7R What would be some of the noteable differences? Is there a certain size scale to go by? Any help is greatly appreciated- James
You'll need to check if the rim widths are the same. And if the spacers fit properly. Also, where the front and rear brake discs line-up with your bike's calipers. There's more that I just can't think of right now.
In the end, it's most likely not worth the trouble. If you like powdercoated wheels, just send yours off to get coated.
</TD></TR></TABLE>You'll need to check if the rim widths are the same. And if the spacers fit properly. Also, where the front and rear brake discs line-up with your bike's calipers. There's more that I just can't think of right now.
