Draft:600RR CA Version vs. 49 State Version
Old Apr 13, 2004 | 11:09 PM
brodric33's Avatar
Default 600RR CA Version vs. 49 State Version
Can anybody tell me all the differencces between the CA version and the 49 state version of the 2004 600RR? Cams, computer, HP, torque, etc.
I'm looking at a sweet deal on a CA bike, but I"m not sure of all the differences.
Thanks in advance.
Old Apr 14, 2004 | 12:35 AM
Lance C's Avatar
Default Re: 600RR CA Version vs. 49 State Version (brodric33)
im not totally sure about the 600rr
but im 80% sure that for the r6 it was 1000rpm difference for the redline.... (cali was 1000 lower than anywhere else)
Old Apr 14, 2004 | 03:35 AM
len's Avatar
len
http://www.600rr.net
Old Apr 14, 2004 | 11:54 AM
DocSean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brodric33 &raquo;</TD></TR><TR><TD CLASS="quote">Can anybody tell me all the differencces between the CA version and the 49 state version of the 2004 600RR? Cams, computer, HP, torque, etc.
Thanks in advance.
I wouldn't worry too much about it. Manufacturers have been doing a pretty good job about not losing any considerable amount of power on CA bikes. I'm willing to bet the only changes would be in the computer....and you might be looking at 2 hp.
Old Apr 14, 2004 | 12:15 PM
SLOWassDA's Avatar
I don't know if this helps but when i bought my hayabusa the only difference i noticed was that the cali version had a smaller gas tank by .5 gallons.......other than that there wasn't a difference.
Old Apr 14, 2004 | 12:37 PM
len's Avatar
len
It's listed in my owner's manual at home, I'll look at it tonight.
Old Apr 14, 2004 | 01:19 PM
brodric33's Avatar
Default Re: 600RR CA Version vs. 49 State Version (len)
that would be coo if you could do that for me
Old Apr 14, 2004 | 01:21 PM
brodric33's Avatar
here is what i got from somone at 600rr.net
1. ECU,
2. Wire Harness,
3. Throttle bodies,
4. EVAP can and vlave,
5. Gas tank,
6. Exhaust headers (2 CATs)
7. 2 O2 sensors.
just wonderin if there is anything else anyone knows?
thanks
Old Apr 15, 2004 | 12:23 AM
.xcalibur.'s Avatar
The california bike has smog restrictions. You might see a catalytic converter which adds weight and affects air flow. Easily solved with a slip on. There will be some extra tubing for a charcoal box only found on CA models. Some bikes have lesser teeth on the rear sprocket. i.e. CA model r6 has 2 less teeth in rear sprocket than 49 state. Cam profiling and ignition timing may be different as well. also higher redlines may differ as well. Ecu will differ for sure. If you try to remove the smog restrictions it will throww off your mapping but then again its nothing a power commander cant fix. If possible, try to stay away from a CA bike unless its an AWESOME deal. hope this helps.
The Hooligan
Honda Motorcycles
20
Sep 27, 2007 07:32 PM
pny1981
Honda Motorcycles
21
Nov 9, 2006 06:35 PM
Tornadom
Honda Motorcycles
29
May 4, 2006 07:03 PM
Kusai.Nihonjin.Desu
Honda Motorcycles
11
Mar 13, 2006 04:21 AM
The_Head
Honda Motorcycles
Feb 8, 2006 12:30 AM
