Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Lumpy Engine deceleration...........
Old Jan 2, 2010 | 01:13 AM
rodentmaster's Avatar
Default Lumpy Engine deceleration...........
Hey ho....
My gen 1 99 CRV (155,000km) has developed a trait of late that the engine deceleration from say, 2500 rpm in 2nd or first gear, the control of the idle/fuel control jerks the car around whereas the engine decay down to 1k rpm used to be non-intrusive. Now the rpm 'lumps' down..........
I have cleaned the idle control valve (but it doesn't gaurantee the actuator action is still smooth or as sensitive). The rear engine torque damper is weak and I suspect it may be a contributing factor.
I apologise if this doesn't describe it the way someone else may word it but it is sort of the way it feels.............it lumps down to idle under in-gear deceration........
Ta.
Old Jan 2, 2010 | 05:04 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Lumpy Engine deceleration...........
When was the last time you changed the transmission fluid?
Old Jan 2, 2010 | 05:40 PM
gearbox and diff oil were done at 100,000km..........- dealer service.
Old Jan 4, 2010 | 05:44 AM
Ross 2.0's Avatar
Is this a manual transmission or automatic?
Old Jan 4, 2010 | 01:23 PM
.........of course.....how silly,...forgot about that!
5spd manual.
It may be normal but just pronounced or more noticeable from the rear engine mount being weakened......but it doesn't show up with the engine warm.
Elvis1977
Oct 9, 2012 02:24 PM
ic89
Oct 14, 2006 02:51 PM
angelovargas
Jul 15, 2004 01:35 PM
cchev
Jan 23, 2004 04:00 PM
