Honda Fit Honda Fit (Jazz)
LED Headlight Bulbs
Old Jan 15, 2025 | 05:49 AM
hondafit2012's Avatar
Default LED Headlight Bulbs
I want to upgrade the headlight bulbs from halogen to LED in our 2012 Honda Fit. The plan is that I purchase the bulbs, then have them installed at a local Honda repair shop.
I want the new bulbs to function as our standard low and high-beam headlights (not fog lights), but I'm confused about what to buy. The options on Amazon seem to emphasize fog lights, have a lot of different types of connections, have fan and fanless varieties, and a bunch of other confusing nomenclature. Can anyone advise what to buy?
Amazon Link Amazon Link
Old Jan 16, 2025 | 06:38 AM
gtr75's Avatar
Default Re: LED Headlight Bulbs
Sylvania has a bulb replacement guide. It says your headlights are 9003.
https://www.sylvania-automotive.com/...2380&oepn=9003
I have personally spent too much on random LED bulbs until I found out the AHC Garage guys use Sealight. I have these on all of my cars with no issues.
Amazon Amazon
I would suggest that you try to replace these yourself instead of paying for labor. It doesn't look hard.
Good luck!
Old Jan 16, 2025 | 12:08 PM
peterZ's Avatar
Loved
Amazon Link
I was originally going to get LED bulbs for my 2020 Fit Sport, but there has been some discussion about them not working when daytime running lights are part of the low beam. They either don't light up or throw a code. I ended up getting Phillips CrystalVision platinum 9003cvps2 bulbs. They are not LED but the beam is almost pure white which is what I wanted. Color temp is 4000. So far I am really liking them and the are a good price on Amazon - $37.99.
peter
Old Feb 28, 2026 | 09:44 AM
jdmDAteg's Avatar
peter
Yes, you are correct about the DRL issues with LED’s. However, I like everyone else who has installed LED’s on their GE8, have simply removed the DRL fuse under the driver side dash and problem solved. The other option is buying a set of ANTI FLICKER CAN BUS MODULES for each headlight (which will run up the price of yor total LED conversion). I installed a set of Sylvania LED’s on mine and removed the DRL fuse and all is perfect. The LED’s are expensive online or stores ($80+) so I opted for FBMP or Offerup to find all mine under $30. One thing to note is, ensure that when installing any LED lamp, you adjust the bulb to have the flat side w/ led diodes facing L & R and the harness pointing downward.
Old Mar 1, 2026 | 03:00 AM
peterZ's Avatar
Loved
I did find LED Projector upgrades specifically for Honda Fit models, and reportedly support DRL. My son had them on his 2013 2ND GEN Sport and he loves them. I plan to get a set for my 3RD GEN Sport in the near future. Pricier than most but specific to the GEN you have.
https://roadmanners.shop/products/h4...tor-headlights
Old Mar 1, 2026 | 08:19 AM
Marrk's Avatar
Loved
Aside from the issue of blinding oncoming cars (Sorry to lie down in front of your parade, guys. ), should there be a concern regarding how much demand the more powerful bulbs place on the battery and charging system?
@gtr75 I appreciate that second video. Thanks.
Yuta
11
Dec 21, 2015 08:17 PM
Awsom-o 4000
Jun 21, 2009 08:52 PM
818blue818
Nov 18, 2008 01:18 PM
nickoz21
Mar 14, 2007 01:37 PM
