Honda Fit Honda Fit (Jazz)
intermittent AC issue
Old Jul 29, 2017 | 06:19 AM
billtmore's Avatar
Default intermittent AC issue
this may already be know on this board but I am trying to get the word out there even more. My 2011 fit had intermmittent AC. The air would turn warm so I would push the AC switch on and off and it would cool again. Sometimes I would turn the car off and back on and that would restore the cold AC. I told the service manager EXACTLY that scenario of the problem. I was given a two to three hundred dollar estimate for evacuating and recharging and some other thing. I was even told there are no relays or switches to the AC. I could see the compressor clutch was not engaging even with the AC switch pushed in and light green. An INTERNET SEARCH found a Honda AC compressor clutch relay switch that seems to be notoriously prone to failure. To be told the AC is freezing up from water and lack of Freon.....I knew that was most likely not possible because many days the AC would run warm the moment I started the car in the morning only to start blowing cold air randomly 20 minutes later. This apparently is a known? issue on many Honda of certain years the Comments for Honda power relay on Amzn shows a high success rate
Strez
Honda Civic (2006 - 2015)
Jun 9, 2015 05:16 PM
PL_RACER
Jul 24, 2012 07:20 PM
Civic Racer X 7
Aug 8, 2007 05:15 PM
