Honda Fit Honda Fit (Jazz)
Front tire alignment
Old May 10, 2017 | 12:27 PM
crazyoldlady's Avatar
Default Front tire alignment
I found out today that there is no adjusting for the rear wheel alignment on my 2008 Honda Fit. The mechanic also told me to ignore the -2.6 camber on the front right wheel as well, because only the toe can be adjusted. Is this true?
Old May 11, 2017 | 06:27 AM
Migz11's Avatar
Default Re: Front tire alignment
Something is off. If BOTH front wheels had the same camber degree then it could be overlooked but if only one is off, then something is wrong. As far as the rear, I'm not sure but it's a front wheel drive car so I would understand if there were no adjustments in the rear.
Old May 11, 2017 | 08:09 PM
claymore's Avatar
Get a new mechanic. He is correct that the rear can not be adjusted but that much - camber on the front is BAD something is BENT.
Old May 13, 2017 | 04:47 PM
eksine's Avatar
Like the other guy says your mechanic is wrong. We just told you what to do. Usually there are aftermarket camber kits you can buy, it is not a factory oem part. The brand i bought was ingalls. Talk to someone who knows what they are talking about.
chjkingme
11
Apr 14, 2013 03:44 PM
corkss
Suspension & Brakes
Dec 2, 2008 11:30 AM
StolenTeg
Jul 2, 2006 11:26 PM
klomast3r
Sep 6, 2005 08:40 AM
