I am Looking For DOHC ZC Vaccum DIAGRAMS
Looking For DOHC ZC Vaccum DIAGRAMS woulde like to see how others have them wired up in there ef hatch or how the vaccums are in general
Re: I am Looking For DOHC ZC Vaccum DIAGRAMS
This is from the workshop manual. Note that this is for OBD0, OBD1 will be different (Throttle body mounted MAP sensor and a different DASHPOT setup). Also note that line #22 that connects to a little vacuum diaphragm does connect straight to one of the three intake manifold ports on some models (some don't have the throttle body mounted vac diaphragm).
https://i109.photobucket.com/albums/...ps65829cee.jpg Your OEM vacuum setup will depend on what country, and what year your ZC is from. |
now to my understanding, i have to plug two vaccum lines on the intake?
if it helps i can get pictures of my setup
Originally Posted by 89brokendownEF
(Post 49710683)
2 Attachment(s)
there is another vaccum left of throttle body in picture, i also need to know where yellow and green wires go on the transmission. look at pics tell me what to do with vaccum lines
From what i can see it looks pretty good. That extra little port on your throttle body should be connected to your MAP sensor (providing it with vacuum). The larger port at the top center of your throttle body connects to the charcoal canister (which it look like it already might be in your pics, hard to see the line routing). The three ports on the front of your intake mani look good too.
Which wires are you referring to (can't see any yellow/green wires)? |
there are two wires that come out of transmission bell housing on transmission
My guess is that you're talking about the reverse switch wires. That's the only two I can think of that connect to the housing.
where do they plug up tho. i cannot find where they go
https://i109.photobucket.com/albums/...psb40a2c13.jpg
This is the wiring diagram, try and find the yellow wire and green/blk wire on your wiring harness. |
i see plugs on harness behind intake minifold, but they both look like female connectors. the wires on trans case seem to be male/female
Originally Posted by ~sp33~
(Post 49711032)
The coolant line that comes off of your intake manifold connects to the coolant line under your throttle body (the port you're talking about). It then connects from your throttle body to your IACV (the little unit with a plug on it at the back of your intake manifold near the throttle body) before returning to your water pump inlet pipe .
Looks like you've bypassed the throttle body coolant line. |
(Post 49715305)
Should be attached pretty close to the portion of the harness that routes under the distributor for the temp gauge sender (single wire) and the thermo sensor. If it's not there though, who knows where it could be. |
(Post 49717518)
Yeah they should be M/F.
(Post 49717515)
If they're the ones i'm thinking of, they're both coolant lines. One is a much larger diameter, and a U shape, the other comes out next to it is maybe 10mm in diameter. That's the one that should connect under your TB.
Post a picture of the two if you can't figure it out. |
Are you missing the dashpot control solenoid?
If you don't have it, the you can plug the line that goes from the dashpot to the intake and then discard of the dashpot (everything associated with the 6, 8, 12, 22 vacuum lines). They sell these vacuum plugs at automotive stores. https://encrypted-tbn2.gstatic.com/i...9i5gv3Ir7weeMo |
