Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda CRX / EF Civic (1988 - 1991) (https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/)
-   -   d16z6 into a crx SI ??? (https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d16z6-into-crx-si-2214676/)
lancerkid06 Feb 1, 2008 05:41 PM
aight i just got a 1988 crx SI ... and the motor is toast in the car ... so i decided i was just gonna put something cheap in it just so it would run but something better than the stock motor ... so my friend told me to do a d16z6 swap ... but i was wondering what all i need to get in order to drop it in ....
i know i need the motor, ecu, and harness .. but what else would i need ..... thanks
zccr-xsi Feb 1, 2008 05:46 PM
well for the z6 swap u will need a p28 ecu ecu conversin harness try to get the obd1 dizzy with it if not ull need one of them too next ull need a dizzy jumper harness so u so can use your si harness with obd1 dizzy.everything for the conversion can be bought from here.
http://www.rywire.com
FYI what everu do please dont try to run it with a obd0 dizzy and a pm6.and i vtec controller to make vtec work trust me it will never run right.
lancerkid06 Feb 1, 2008 06:15 PM
so if i get the obd1 dizzy, dizzy jumper harness, p28ecu, and ecu conversion harness ... it will drop right in ... and i wouldnt have to use a vtec controller then would i ... cause i wasnt planning on using one unless i had to .. but thanks for the link i'll check it out
dr_latino999 Feb 1, 2008 08:32 PM
Re: (lancerkid06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lancerkid06 &raquo;</TD></TR><TR><TD CLASS="quote">so if i get the obd1 dizzy, dizzy jumper harness, p28ecu, and ecu conversion harness ... it will drop right in ... and i wouldnt have to use a vtec controller then would i ... cause i wasnt planning on using one unless i had to .. but thanks for the link i'll check it out</TD></TR></TABLE> You can make the harnesses yourself if you are ever so electronically inclined and save some cash. And please mail your VTEC controller and any your friends may own back to 2001 please https://honda-tech.com/forums/images/smilies/emthup.gif
gnar kill Feb 1, 2008 09:48 PM
Re: (dr_latino999)
I am running z6 with p28 and conversion harness...swap is really easy. If you need a dizzy I got a brand new one I got from dizzy king lying around that I haven't used and need to unload pm me if interested
lancerkid06 Feb 1, 2008 11:03 PM
can you tell a diff. with that motor over the stock motor .. cause im planning on going turbo with it later on if its a good enough motor ...
zccr-xsi Feb 2, 2008 04:16 AM
yea!plus ull have vtec in the z6.
