Check Engine Light Problem Please Help
back to the engine light problem... i see no flashing light under the passenger side carpet, so im thinking just go to autozone to let them check code? oh and another problem i have is the wheel looks bent in, how do i fix that? do i just adjust the coilovers? or adjust the camber kit? or will an alignment fix this problem? ... some people may like that but i think it just dont look right
autozone doesn't check the codes anymore...you might have to go to a auto repair shop and have them run it through the diagnostic machine to figure out why your cel is on but not throwing a ecu code...!!!
well dang that sucks, could it be when i stoped and got gas that i didnt put in on as good as i thought i did, i mean i checked it but it was tight on there.... i think i might have messed something up when i changed from 4th back to 3rd
ph0shizzle
May 13, 2006 08:36 PM
