Charcole canister removal for 91 civic
<center>
https://i29.photobucket.com/albums/c...eg6/sensor.jpg </center> were trying to clean up the engine bay in my buddies 91 sohc vtec turbo. there are some vaccum lines running from the canister up to this sensor, and theres also one for the boost gauge that t's into a line that goes between the intake mani and the canister. onto of this sensor theres a plug coming out of it leading into the main harness... is there any way to safely take out the canister without throwing a check engine or anything like that? |
yea you can remove it just block off the vac lines on the intake manifold.
Re: (Beau Gotti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beau Gotti »</TD></TR><TR><TD CLASS="quote">yea you can remove it just block off the vac lines on the intake manifold. </TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif Just dont plug the gas vent line on the firewall. And no codes will show up by leaving the plug unpluged. |
Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">
And no codes will show up by leaving the plug unpluged.</TD></TR></TABLE> Yup. Whether you're obd0 or obd1 |
Re: (SECURITY)
what about the vaccum line for the boost gauge? should i just run that directly onto the intake mani? can i unplug that sensor so i can lose that whole thing on the firewall too? since there will be no vac lines hooked up it really wont be doin anything....
id say use the Vac line from the FPR
Re: (Beau Gotti)
so if i take that sensor out and its no longer plugged in that wont affect anything?
Re: (spoonjdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonjdmdc2 »</TD></TR><TR><TD CLASS="quote">so if i take that sensor out and its no longer plugged in that wont affect anything?</TD></TR></TABLE>
No the evap can be removed with no sideeffects. |
What about emissions? Does it have anything negative in the regard? How about fuel economy?
Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">What about emissions? Does it have anything negative in the regard? How about fuel economy?</TD></TR></TABLE>
It still polutes less then anything from GM https://honda-tech.com/forums/images...s/emsmilep.gif I seen no change in anything, as far as i can tell all it does is run the vented fumes from the gas tank through the motor and we are now just venting into the air. |
Its really bad, actually. Hydrocarbons (unburned gas) is really bad for the enviornment, much more so than more burned gas.
