Honda CR-V & Element 2WD & 4WD Element & CR-V
Will not start
Old Jun 14, 2022 | 04:34 PM
LordDread 77's Avatar
Default Will not start
03 element 288000 miles.
over heated and dumped all water/antifreeze on ground.
It was late so it sat till morning.
refilled the water/antifreeze..
When i attempted to start it...it would not start.
any ideas on how to diagnos the problem?
Old Jun 15, 2022 | 06:46 AM
DCM1's Avatar
Default Re: Will not start
Do a compression test, probably have a blown head gasket.
Old Jun 15, 2022 | 12:11 PM
ThisIsMatt's Avatar
Does it crank and not start, or does it not even crank?
Old Dec 19, 2022 | 06:16 AM
Crank but no start.
I have since tried to do a compression test but when trying to take the Coil packs out I broke 2 of them. So obviously I have another problem.
I am guessing when it got hot those plastic coil packs melted .
So what is the best way to get those coil packs out Before going any further?
Old Dec 19, 2022 | 01:18 PM
ThisIsMatt's Avatar
Get a nice long pair of needle-nose pliers and see if you can get a good grip on the boot, then yank. If you have the kind of needle-nose pliers where the ends are kind-of bent in a circle (for pulling hoses off hose barbs), they may work even better.
Side-question...is there any sign of oil in the sparkplug wells? Oil will destroy the rubber that the boots are made of if it's submerged for any length of time. Once the rubber is compromised, it's entirely possible the spark that's supposed to travel to the spark plug will instead travel through the boot into the metal that forms the spark plug tube. This could cause a crank-no-start if the spark isn't making it to the spark plug.
Old Dec 20, 2022 | 08:10 AM
DCM1's Avatar
If the engine was hot enough to melt the coils packs, your whole car would have burned up…those are designed to withstand high heat, so something else must be playing into them breaking.
The “boots” are silicon, not rubber.
sugarman
Jun 27, 2018 10:54 AM
antig24
Sep 3, 2010 12:13 PM
Sutterlude
Apr 4, 2009 09:19 PM
diesel4304
Sep 28, 2005 06:30 AM
