Honda CR-V & Element 2WD & 4WD Element & CR-V
speedometer intermitent
Old Jul 5, 2018 | 05:14 AM
mickjc64's Avatar
Default speedometer intermitent
sometimes it works fine other times it stops
Old Jul 5, 2018 | 07:47 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: speedometer intermitent
What year and model?
If it is a 94-97 Accord and there is no Check Engine Light with a trouble code related to the Vehicle Speed Sensor, then it is most likely the speedometer circuit board. You can try to touch up or re-solder the solder joints or just replace the circuit board from a used cluster so you retain your current odometer reading. There are many threads already regarding this issue. Quite common issue with the circuit board.
Old Jul 5, 2018 | 12:55 PM
mickjc64's Avatar
The vehicle is a 2006 Honda CR-V, and the speedo has an intermittent problem sometimes it works fine other times it stops maybe VSS?? mickjc64
Old Jul 5, 2018 | 01:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
You posted in the wrong sub-forum, so I moved the thread.
Eric Revell
Feb 17, 2018 10:19 AM
Sonic13v
Oct 23, 2017 09:41 AM
mmurphy
Mar 24, 2006 10:07 AM
Jackadeal
Mar 10, 2006 03:18 PM
dc2nick
Oct 30, 2005 05:10 AM
