Honda CR-V & Element 2WD & 4WD Element & CR-V
Shaking under Acceleration
Old Apr 29, 2014 | 04:18 PM
petrolhead89's Avatar
Default Shaking under Acceleration
Hi Guys,
I am new to the forums. This is my first thread created. I have seen several threads about a car shaking and all of them have been solved. I have already done all of the maintenance thought of so i come to you.......Here is a list of the things that have been replaced
Upper and lower control arm left side
cv axles
removed propeller shaft
struts
sway bar links
full steering rack
ball joints on right side
The vehicle shakes terribly under acceleration. shakes a very slight amount(hardly noticeable) when driving at constant speed or braking. I cannot find out the issue. Any ideas would be appreciated. I am wondering if a harmonic balancer could cause shaking like that?
Old Apr 30, 2014 | 04:19 AM
dogbiscuit's Avatar
Default Re: Shaking under Acceleration
Have you thought about a bad wheel bearing? when the car is jacked up and the front wheels are off the ground do the wheels have any vertical axis play?
Old Apr 30, 2014 | 09:08 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Wheel bearings are VERY common on the first generation CRVs. In most cases vibration under acceleration only can be traced back to bad axles or wheel bearings.
Old Apr 30, 2014 | 12:03 PM
kiseliok's Avatar
I have slight vibration @20 mph because of the aftermarket axles, but it goes away if I go faster or slower.
Old Apr 30, 2014 | 05:02 PM
dogbiscuit's Avatar
I say that because I just replaced my front passenger side bearing this evening.
Mine didn't shake much but sounded horrible at each bump.
Old Jun 1, 2014 | 04:46 PM
SupaFly's Avatar
I've had several first gens usual problem is the front rubber bushing in the rear trailing arm is dry rot ... can almost guar that is the issue.. difficult to see but check it.
Old Jun 1, 2014 | 09:06 PM
www.megameet.org's Avatar
Bearing will give you noise. If it shakes like your loseing traction doing a burn out, its the axle
Old Jun 2, 2014 | 09:09 AM
DO IT ON ALL FOURS
You have to be joking... a bearing CAN give noise. I have changed DOZENS of wheel bearings that had almost 1/4" of lateral run out and zero noise. Also, not all cars have wheel hop issues when doing a burn out. If they do you either have the suspension set up wrong or are doing the burn out at much too low of a speed.
The rear rubber bushing won't cause vibration from acceleration. I have changed my fair share of them. They will cause poor alignment and if it gets bad enough a knocking sounds from bumps and possibly during deceleration.
Old Jun 2, 2014 | 12:40 PM
shermanyang's Avatar
since you've removed your drive shaft I'll rule out bad u-joints. Have you had your alignment checked? Or your tires balanced? Out of balanced tires can definitely cause the shaking you're having.
Old Jun 3, 2014 | 02:19 PM
A burn out at the track, which can cause wheel hop. Its the closest thing i can compare it to. I havent ever personally had a bearing bad without noise. Honda only.
Rarytas
Sep 10, 2012 06:08 PM
wgbm92
May 21, 2011 02:03 PM
94civiccupew/b7
23
Dec 11, 2009 06:27 AM
blackccoupe
May 23, 2005 04:19 PM
jdmazm
Apr 28, 2005 07:57 PM
