Honda CR-V & Element 2WD & 4WD Element & CR-V
b20 VTEC torque specs???
Old Nov 6, 2007 | 09:09 AM
MyHotsh's Avatar
Default b20 VTEC torque specs???
My cousin is doing a b20VTEC . He has a B20z with a B16 head.
What specs should he torque the headbolts? (b16 head specs or b20 block?)
also where do the dowel pins go?
thanks in advance for any useful info!!!
Old Nov 6, 2007 | 09:10 AM
Luserkid's Avatar
Default Re: b20 VTEC torque specs??? (MyHotsh)
What bolts is he using? Dowel pins go at the end bolts, just put them in the holes that fit the head and go from there.
Old Nov 6, 2007 | 09:25 AM
MyHotsh's Avatar
Default Re: b20 VTEC torque specs??? (Luserkid)
stock b16 headbolts
Old Nov 6, 2007 | 10:22 AM
Luserkid's Avatar
62ft lbs (i normally do 65)
Old Nov 6, 2007 | 10:23 AM
HAMOTORSPORTS's Avatar
DONT USE B16 HEAD BOLTS!! THEY ARE SHORT. USE GSR.
Old Nov 6, 2007 | 10:34 AM
MyHotsh's Avatar
Default Re: b20 VTEC torque specs??? (HAMOTORSPORTSUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAMOTORSPORTSUSA &raquo;</TD></TR><TR><TD CLASS="quote">DONT USE B16 HEAD BOLTS!! THEY ARE SHORT. USE GSR.</TD></TR></TABLE>
thank you..i dont think he is aware of that!
Old Nov 6, 2007 | 02:30 PM
BILLY_BLING's Avatar
I have a set of arp heads studs for 20block and a b 16 head for $100
Old Jul 10, 2013 | 09:42 PM
roger_ruizz's Avatar
Does anyone know the right head tourque spects for a b20 vtec? I searched it up and different patters and different tourques came out? Thanks..
Old Jul 10, 2013 | 11:42 PM
NZ-DB8R's Avatar
Headgaskets normally come with what torque settings you need, or at least all the ones Ive bought did
Old Jul 11, 2013 | 08:25 AM
dogbiscuit's Avatar
should prolly put ARP studs on there.
Old Feb 19, 2021 | 11:01 AM
Leshwan's Avatar
arp head studs torque setting?? b20 block b16 head
NorCalHB
Feb 1, 2012 07:01 PM
clayton bigsby
Oct 19, 2006 11:34 PM
MAUCH3
Feb 26, 2005 05:26 PM
igy
Nov 3, 2004 05:12 PM
