2013 Timing Chain Replacement
I've done a search about when to replace the timing chain on a 13 CR-V and I can't find a definitive answer. I've read where the chain will outlast the car and I've read that the chain should be replaced around 100K miles. My 13 CR-V has 96K on it. When should I replace the chain??
Re: 2013 Timing Chain Replacement
Generally, no the timing chain doesn't need to be replaced unless there was an issue with it.
Originally Posted by tech8
(Post 52771504)
When timing codes show up then it may need to be changed.
I have an 04 Element with 225,000 plus miles and have never charged the timing chain. Unless you have an issue with it, leave it alone.
You know that your chain is up for replacement when your engine begins to make a loud coffee grinder noise, but even then you have at least a few thousand miles to go before you really have to do it. This type of repair is best to be avoided.
Originally Posted by canister
(Post 52774412)
Originally Posted by OldRider
(Post 52774423)
I'm going to adjust the valves over the Winter and take a good look at the chain and guides then.
The valve adjustment is always a good idea. |
260k in an Element, heavy turd of a wind sail that demands everything a K can offer. 310k in a TSX. Another 190k on a Civic and other TSX.
All original timing chains. These engines are tough if you keep the oil changed. |
| All times are GMT -8. The time now is 09:23 PM. |
