Honda CR-V & Element 2WD & 4WD Element & CR-V
2003 CRV blinking D codes
Old May 30, 2014 | 06:29 AM
m_wnzl's Avatar
Default 2003 CRV blinking D codes
I manually pulled code 26 from the blinking D indicator, but I have been unable to find what that code is or any transmission code for that matter. Please help asap, my daughter needs her car.
thanks in advance!!
Old May 30, 2014 | 07:17 AM
UK-Kev's Avatar
Default Re: 2003 CRV blinking D codes
Hello,
It would help if you could advise what symptoms you are having with your CRV, also mileage and any service information.
Below is the generic information relating to error code P0026 .
Symptoms of a P0026 DTC may include: MIL (Malfunction Indicator Lamp) illumination Poor acceleration or engine performance Decreased fuel economy
Potential causes of a P0026 diagnostic trouble code may include: Low engine oil level or contaminated oil Clogged oil system Malfunctioning control solenoid Malfunctioning camshaft actuator Timing chain/belt loose or incorrectly adjusted Malfunctioning ECM/PCM.
Rgs,
Kev
Old May 30, 2014 | 07:34 AM
m_wnzl's Avatar
the Drive indicator started blinking. No performance changes noted. No CEL light on. I manually pulled code 26 ( 2 slow flashes, then 6 rapid flashes) of the drive indicator. I believe the code you gave me was for a CEL code, not the transmission.
Old May 30, 2014 | 12:47 PM
UK-Kev's Avatar
Hi,
FYI check engine light code 26 = ODB2 >>> P0026 of which I have given you the correct generic information.
Rgs,
Kev
Old May 30, 2014 | 01:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Originally Posted by UK-Kev
Hi,
Rgs,
Kev
Incorrect.
If the Diagnostic Trouble Code (DTC) is retrieved by shorting the SCS terminals instead of using an OBD-II reader/scanner, DTC code 26 is equivalent to P0845 - 3rd Clutch Pressure Switch.
Old May 30, 2014 | 07:24 PM
m_wnzl's Avatar
Thank you so very much Tech8. I dont know where you found that chart cuz I was searching all over the place, but I really appreciate it. I will be ordering that part right away.
Old May 30, 2014 | 07:32 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Normally, I wouldn't just throw a part at an issue; but, it may just be the switch. Here is an image of the location, it has a Blu/Wht wire. Blu/Wht is a wire with blue colored insulation and a white stripe running through it.
Old May 31, 2014 | 03:24 AM
UK-Kev's Avatar
Originally Posted by tech8
Incorrect.
Hello Tech8 / m_wnzl,
Hello m-wnzl,
Please accept my apologies Tech8 information is correct and I hope I did not cause you any inconvenience.
Hello Tech8,
Thank you for bring this error to my attention and having now checked our database, I have found a few anomalies and I have requested our nomenclature team to fix this problem.
Thanks very much appreciated.
Kev
Thanks & Regards,
Kev
Old May 31, 2014 | 06:39 AM
m_wnzl's Avatar
Tech8, thanks for the pic too. All I had found were diagrams of its location. Again, I very much appreciate your knowledge and help.
UK-Kev, apology accepted. I can understand the confusion. I appreciate the input.
Thanks Honda-tech.com !!!
Old May 31, 2014 | 02:53 PM
paulm999's Avatar
"D" blinking? No symptoms? Pulling a code for the 3rd clutch pressure switch? Before you condemn and replace the 3rd clutch pressure switch, check the ATFluid level with a warm engine and on level ground. If the level is 6-8oz low, the D will flash and the code will be thrown. If the ATF is low, you have a leak somewhere. Start looking at the axle seals on the trans. It may appear to be a very minor leak, but you will loose 6-8oz of ATF over 1-2000 miles. Most of the time, the right axle seal leaks first.
jloobee
21
May 8, 2021 08:29 AM
buttercup
Aug 9, 2015 06:39 AM
jacob83blizz
Honda Civic (2001 - 2005)
Oct 28, 2011 03:07 PM
ballerchild
Jun 28, 2006 12:27 PM
