Honda CR-V & Element 2WD & 4WD Element & CR-V
08 CRV Engine Swap Problems
Old May 15, 2023 | 05:48 AM
Nightlyfe's Avatar
Default 08 CRV Engine Swap Problems
Hello everyone, I am new to the site, but I am in need of help badly! I purchased a 08 CRV a couple months back from a car lot and I started doing Maintenace to it just to make sure everything was good with it since not knowing the history of it. I have had problems since day one with it being slow and sluggish and horrible on gas, but I figured it just how the crv was I know they weren't built for speed. It won't till about a month ago I was replacing the transmission filter when I finally noticed that it was a K20z3 engine in it instead of the stock k24z1 had been swapped in it due to the stamp mark on the motor. Still has the stock crv 2wd transmission mated to engine, still running the stock crv ecm, there are no check engine lights on and no stored or pending codes from ecm, starts and idle fines. It has nooooo low end power at take off till about 4-5k rpm, its horrible on gas, boggs down at 2k rpm when speeding up trying to pull out in traffic, I have changed all filters, new coil packs and spark plugs, new throttle body with new tps sensor(for the k20z3 engine), new map sensor, new oxygen sensors, new maf sensor. Trying to figure out what I can do to solve this problem cause daily driving it is horrible when it comes to performance and gas milage.
Old May 16, 2023 | 05:19 AM
starchland's Avatar
Default Re: 08 CRV Engine Swap Problems
Which ecu?
Old May 16, 2023 | 05:27 AM
Nightlyfe's Avatar
The stock factory 07 crv ecm
Old May 16, 2023 | 05:57 AM
starchland's Avatar
I would think the fuel trims and stuff would be off. No engine codes too huh. Can you check the live data?
Old May 16, 2023 | 06:25 AM
Nightlyfe's Avatar
Yeah no codes for anything, I have done a live data scan and everything looks good so far from what I have seen reading the forms. But my question is, with being an automatic what ecm should it be running for this engine, I have a 07 civic si ecm but all of those were manual transmissions so I know I couldn’t run it, I have plugged it in before and car will start but immediately cuts off every time and I am assuming that may be because of the immobilizer system. Not sure what else to do
Coolbreezex82x
Sep 17, 2019 11:20 AM
MyWhiteEJ6
Mar 21, 2015 10:48 PM
ekcivic2
Jun 17, 2013 10:07 AM
G-Gore
Jan 10, 2006 07:37 PM
hardcorelolo
10
Jun 2, 2004 11:28 AM
